Old 12th August 2017, 06:18 PM
norton norton is offline
Air intake.
That filter is complete garbage though and hits the underside of the nose so I have a straight rather than tapered filter on the way.
Old 14th August 2017, 04:26 PM
Has anyone had any joy shortening an Escort steering rack?
I've got the rack mounted as low as I can but the amount of bump steer it has seems a bit crazy. That's with the wheels at maximum droop (and I've used inch longer shocks than Saturn originally suggested).
Old 17th August 2017, 11:30 AM
mopple mopple is offline
Try to put some washers/shims under the rack and/or to move rack further/back.
Old 18th August 2017, 09:20 AM
That'll raise the rack and will further exaggerate the effect. I can't get it any lower.
Old 12th September 2017, 11:46 AM
Does anyone know if a motorcycle fuel tank cap would pass IVA?
Old 1st October 2017, 03:12 PM
Here is my dash switches!
Old 15th November 2017, 02:28 PM
Can anyone educate me a little on fuel tank requirements?
I have a tank using an MX5 sender/pump unit. This has a high pressure fuel feed and a return built in. I also have a filler neck.
Now what do I need for vent/rollover? The has an 8mm barb welded onto it but I'm not sure what use this'll be. I also have a rollver over ball valve that's awaiting fitting.
Now would I be right in saying I only need the ball valve to allow for air displacement when filling, air intake when fuel is used and to then stop fuel spillage should I run out of driving ability?
Old 17th November 2017, 09:01 AM
Ianr Ianr is offline
That sounds about right. Mine uses the MX5 pump sender with flow and return pipes. I also use the MX5 filler and my 8mm top pipe connects to an 8mm hose with a non return ball valve the hose then loops down to the bottom of the car rather than finish in the boot area. Passed IVA with that system Oct 2016 and been ok on the road since
Old 17th November 2017, 09:19 AM
That’s reassuring, thank you.
Old 30th March 2018, 08:21 PM
Hey guys, I had a little break form the car after a cold winter and a new job but I'm gearing up to get cracking again.
I've just bought a new compressor for this year as I hope to up my game with spraying components and I'd like to paint the car one day.
Has anyone any experience with home HVLP setups?
I have a Graco gun in mind and will use a gun mounted regulator but I'm unsure what kind of wall mounted filter/water trap/regulator to use and will 1.4 fittings flow enough air?
The gun I want to get requires 7cfm of air and the compressor I have outputs over 14cfm.
