#141
![]() Happy to get my IVA pass today at Leighton buzzard, great test centre.
Enjoyed the 30 miles home, the drive there was nerve racking, I thought will it break down, overheat, wobble. On the way back gave it the beans. Goes ok for a CVH, need to swap my jets for 1.6mm from the 1.4mm standard one, that should see a few more horses out of here until zetec over the winter. ![]()
Build Cost so far £xxx (Given up adding it up) - She Starts!! Build Thread Here: http://www.haynes.co.uk/forums/showthread.php?t=5501 |
#142
![]() Congratulations! Car looks stunning.
#143
![]() Well done Mike! Great Job!
And good timing with spring/summer too ![]()
#144
![]() thanks all, it was a long hard slog to this far. Still loads to do:
setup windscreen zetec conversion willwood brakes bigger fuel tank better trimming on the tunnel etc etc etc ![]()
#145
![]() Just spent time reading through your entire build. Very nice! I'm loving those rear lights - where did you get those? I also have the OBP pedal box, but I'm using a Miata (MX5) donor. Still sorting out what I'm going to do with the throttle.
I say get a helmet, set up the car, and drive it all summer long!
My build: http://locostusa.com/forums/viewtopic.php?f=35&t=3774 |
#146
![]() Yeh I think I replied on locostbuilders. There's probably a better way to get the throttle sorted, a nice bell crank would make it all a lot more adjustable and no welding the peddle box. Don't think OBP are that helpful with that pedal box and the throttle it could do with a return spring and some adjustment as standard for a few extra £.
Think the lights are from boltonbits on ebay, not forgetting the fog light isn't a fog light and will fail IVA as id doesn't have a F mark on it. I got a helmet to drive it to IVA, so it will be on the road as soon as the paperwork comes through
#147
![]() Very well done, I bet the relife is huge and you probably have a bunch of new friends looking for a lift
![]() TT
#148
![]() I've done 250 miles now.
dropping the tyres pressures and dialing back the shocks has made it driveable on the bumpy b roads I'm surrounded by. It could do with a bit more shove, I have one jet size to go up but then i think its Zetec time. I'm not sure if I can wait until winter!
