Old 7th January 2019, 02:06 PM
H-L-Smith H-L-Smith is offline
Yes, your work is very impressive. The shop in the background of these latest photos hints at some involvement with sculpture, which would be a confidence builder. Even so, those clamshell shapes are a complex and sophisticated 3D shape, and your work looks excellent. They are quite an accomplishment.
Old 10th May 2020, 10:21 PM
robj robj is offline
Evening everybody, it's been a while since my last post so I thought I'd give you all an update.
managed to get the rear arch metal work finished.
Built a new exhaust
put a bracket for the headlight front indicators together just need to make the bracket that attaches to the clamshell wings.
Old 10th May 2020, 10:30 PM
Thought I'd start on the trans tunnel cover.
Old 10th May 2020, 10:36 PM
Start off by making a foam pattern then moulding it.I then produced a wax from the mould and got it cast at work, then a lot of sanding later got the metalwork finished just need to make some gaiters the handbrake and gear lever.
Old 10th May 2020, 10:39 PM
started to rough out the dash but still need to do some more work on that so will need to do another update when it's finished
Old 10th May 2020, 10:44 PM
Started work on the inlet manifold as well, using a set of triumph speed four throttle bodies hope they work out ok I've spent a while putting these together.
Old 11th May 2020, 06:01 AM
Some amazing work there, really true craftmanship.
Old 11th May 2020, 07:42 PM
Thanks twin turbo. Trying to make the most of the lock down and get a good bit done.
Old 11th May 2020, 07:49 PM
jps jps is offline
Amazing work. I would say it's inspiring, but i'm just off to the garage to start chopping my car up with the hacksaw....
Old 17th May 2020, 09:58 PM
evening all bit more of an update managed to get chance to start work on a rear diffuser still got to work out the fixing points but it's a start.
Also managed to get some brackets made for the seats. They're 3rd row seats out of a volvo XC90 not a bad fit.
