Old 12th March 2009, 11:58 PM
A stim is a simulator.
This plugs into the megasquirt ECU. It enables you to test the functions of the megasquirt, simulate engine loads & allows you to set the basic settings via the tuning software.
If all goes well. The engine should at least start once you have pre-configured the ECU with the stim.
That's the theory anyways
If you have bought a ready built unit it would have been set up using a stim.
Old 15th March 2009, 10:50 AM
Danzetec Danzetec is offline
Originally Posted by Bonzo View Post
Hi all.
Having tried the msextraefi web site I find it is no longer available.
Your looking for www.extraefi.co.uk - good quality ECUs that come with warrenty and if you provide your spec he will load a base map to get you started
Haynes roadster parts and bespoke fabrication - www.oweneng.co.uk
Old 15th March 2009, 11:09 PM
Talking Finished
I have finished the constrution of my Megasquirt unit this evening.
It took 4 good evening sessions to complete. Mainly reading, reading & more reading.
All I need to do now is to set it all up on the stim
It was quite realaxing work to be honest, it has been a long, long time since I have done any electronics work.
Didn't even get close to chucking out of the window
Old 15th March 2009, 11:13 PM
looks good Ronnie, maybe not out of the window ??, but possibly a few harsh words thrown at it??????
i wouldn,t know where to start
Old 15th March 2009, 11:34 PM
The construction was quite easy, the component locations are very well defined on the board, all of the component packs were also very clearly labled.
I did chuck a few F's when I wired up a set of jumper wires up to use the EDIS 4 module.
A bit further on I had to change them all around.
A bit further on, I found that they were in the right place the first time
Old 15th March 2009, 11:43 PM
whats that old saying????? " measure twice , cut once" sort of applies me thinks, smiles, ah you can build mine if i ever need one
Old 16th March 2009, 03:18 AM
bloomin heck that didnt take you long. mine is still in all the little baggies until sometime in the future when i need it. your not f'in and blinding now but you will be when the stim turns up. what stim did you go for as there are a couple.
as for the manual its a bloody good read if you want to understand how modern fandango things work. only wish i had the manual when i was at uni as it would have come in usefull for the ecu and interface that i designed for my disertation lol.
Old 16th March 2009, 09:15 AM
fabbyglass
What a right box of devil sent bits....gives me a headache just looking at the picture
Old 16th March 2009, 09:19 AM
I went for the version 2.2 stim.
Yes I am saving my finest language for when I connect the stim
I did read the construction manual several times before I began.
What I did not do was to cross-reference all of the ignition options available properly
The small transistors were rather delicate to solder, so, so easy to bridge the pins with solder.
I was there with my glasses on & using a magnifying screen, still was unable to see 100%.
I ended up asking my eldest to check them for me. All ok though.
Old 16th March 2009, 09:43 AM
That's what I thought when I first opened the box.
OMG it's a kit, kit, kit
My eldest said " I think you should throw that in the bin before you start "
The constrction followed quite a logical sequence & was relatively easy to follow.
After being stung for the VAT by customs, I have probably saved just over £100.
Not that saving money was at the top of the list. I feel that I would now have the insight & confidence to adapt the unit to suit other things that I may want to do in the future.
