Old 21st March 2009, 08:13 PM
swe7 swe7 is offline
Default Disc brakes
Hi all.
Can i fit disc at the rear if i dont have a ABS donor?
What year did the sierra come with ABS?
Peter.
Old 21st March 2009, 08:49 PM
Rear disks were fitted as standard to the 2litre DOC Sierra GLSI & XR4i.
Abs was also available as an option on other models, these would have also been fitted with rear disks.
There is nothing preventing you from fitting rear disks if you are able find the components needed.
If memory serves me right. You will need Rear uprights made to suit disks Or adapters such as the ones 3ge sell.
I am not sure if the drive shafts need changing. Rear disk Sierras were fitted with the Lobro type shafts.
Old 21st March 2009, 09:02 PM
Thanks Ronnie.
Chassie work mowing on slowly, and still searching for the right donor.
Peter.
Old 21st March 2009, 09:09 PM
Originally Posted by swe7 View Post
Thanks Ronnie.
Peter.
Don't panic. Keep on plugging away on the chassis.
A donor will no doubt turn up out of the blue when you least expect it.
Old 21st March 2009, 09:10 PM
Hi Ronnie.
I did see the disc adapters in the other tread. Now i understand.
Peter.
