Old 10th April 2009, 04:50 PM
mdasseville mdasseville is offline
Question Zetec to mt75 gearbox Starter problem?
Hi All
I have a Zetec 2l Black top engine and and mt75 Rear wheel gearbox,
Long story:
One sits in one shed and the other sits in another!!
Well my problem is,.....
When looking at the engine from the front of the engine the Starter motor is on the left hand side,...but the starter in the gearbox is on the right
What do people do to make these work together???
Thanks
Mike
Old 10th April 2009, 08:00 PM
im not 100% sure so dont take my word on it but i think people use the cvh starter motor.
Old 10th April 2009, 09:04 PM
Ash is correct, you need to use the starter from the 1800 cvh engine. They are not easy to find on their own but Lucas LRS707 is the same. I've just ordered a new one for mine from:
http://www.forge-services.co.uk/acatalog/LRS.html
You'll need to grind quite of bit off the Zetec Blacktop sump to fit it unless you are planning on changing the sump anyway, the cvh sump also fits by moving the bolt holes slightly and is easier to shorten being steel rather than ali.
Andy
Old 11th April 2009, 05:34 PM
Question
Thanks
Ashg /Andy,
Just one more question,...
What fly wheel and cluch are you using?
As i have the 2l zetec fly wheel ,pressure plate, and plate!
and also the 2l dohc 8v fly wheel ,pressure plate, and plate!
will any of this be any good to use?
Thanks
Mike
Old 11th April 2009, 06:05 PM
Originally Posted by mdasseville View Post
Thanks
Ashg /Andy,
Thanks
Mike
Not sure about the dohc flywheel and clutch but i used the 1.8cvh with the addition of a new spigot bearing but that was onto the type 9 gearbox, cvh has a lighter flywheel but you loose the timing wheel which you can attach to the front pulley wheel.
If in doubt try the locost forum, i got some good advice from there.
Andy
Old 23rd April 2009, 10:12 PM
Cobra289 Cobra289 is offline
Thanks
Ashg /Andy,
Thanks
Mike
We have [continental cars] the same problem but at the other side.
Find the starter motor the rest will fit.
Cut a bit of the aluminum part of the oil pan [not oil involved at that area] and that is solved.
Visit some sites with Westfield Build and you will see.
This is a picture of the 3D Zetec watch the area that you need to cut.
Regards,
Cobra289
http://www.donostia.demon.nl
'Improvement' means that you recognize previous mistakes!
Old 30th April 2009, 10:07 PM
snapper snapper is offline
Other options are the RS2000 ally bell housing (this has a starter hole on both sides) on a type 9 with a Zetec 1800 flywheel and a CVH starter motor
Old 13th May 2009, 08:40 PM
thanks everone .
going to get my grinder out
