Old 10th May 2009, 09:38 AM
DaveW DaveW is offline
Default Best Donor car for a haynes 4x4 4wd car
Can you help on this one
Best regards David
Old 10th May 2009, 09:57 AM
That would be a hard one to do.
A 4X4 would require a complete re-design of most of the front end.
The Sierra XR4 would seem an obvious choice although i don't think you will overcome the sump clearance issue.
That would leave the Subaru & Audi options
aaronbassett aaronbassett is offline
sierria 4x4 if you can make every thing fit
my blog
Building is just another word for progress
Old 10th May 2009, 01:44 PM
Chris Gibbs
Google "Dax Quadra", this was a Sierra 4 x 4 based car.
The problem with the system is that the transfer box on the gearbox for the front prop/differential is on the drivers side of the gearbox and therefore takes up space in the drivers footwell.
There's also a 4 x 4 Locost, try a search on the Locostbuilders forum.
Chris
Old 10th May 2009, 05:59 PM
my question to all is why would you want a 4x4 roadster?
im building a roadster because i wanted a small fast rwd car. why? because they are more fun that way!
i dont think its impossible to do and i would be very interested to see how someone goes about it. i just can't see the major advantage on such a small light car compared to all the extra weight and the time/effort put into developing it.
you never know one day they may start off roading roadsters then it will be a great idea
Old 10th May 2009, 08:29 PM
fabbyglass
RWD much better and a lot more fun especially in the wet
I have my own section of "hillclimb" on the way to grp suppliers so drive it like a complete knob but boy is it fun and a damn fine way of relieving stress..I arrive with a smile everytime
Old 10th May 2009, 09:34 PM
A lovely bit of road Mark
Lets hope we never meet when I am driving like a bell end
Old 11th May 2009, 12:56 PM
Wink
200 km daily to my Works
Old 4th November 2009, 09:21 PM
chrisunwin chrisunwin is offline
I have pondered the 4X4 option, the only way I can see to do it is to use the engine and box from a front wheel drive car, turn the whole lot through 90deg, then mate the drive shafts to dfis front and rear. BIG problem is that the diffs will need a 1 to 1 ratio. Good luck finding them.
Regards
Chris
Old 4th November 2009, 09:26 PM
Regards
Chris
You have confused the hell out of me there. Why would you need a second gearbox? Just use 4x4 running gear from, oh lets see, a Sierra 4x4??
I asked this question some time ago on the LB forum, and whilst it can be done (and has been - although not a Haynes) it is a lot of work, involving inboard shocks to avoid front driveshafts etc.
Link to LB discussion on 4x4 locost/haynes
Sean
