Old 25th May 2009, 06:38 PM
Tatey's Avatar
Tatey Tatey is offline
Personally i would much prefer to trust Chris and the Haynes name and over prepair, compared to someone from a steel company.
Chris seems to have done a lot of work getting the car to where it is now.
And would you really want to risk buying inferior steel for a car that you and another people would be in?
Would you be able to live with yourself knowing that you might have injured/killed someone close to you because you wanted to save a few £'s?
Old 25th May 2009, 07:16 PM
Land Locked's Avatar
No argument with any of these points, just having trouble sourcing the good stuff locally.
Old 26th May 2009, 07:06 AM
The reason i quoted Chris' post was cause he didn't specify the wall of the RHS that would make it heavier. As I understand RHS and ERW have the same density.
So the question I didn't ask (I plead lack of sleep), Is it the RHS thats heavier or more dense or is it because of the wall thickness that the RHS would be heavier and more likely to break than deform?
However at the end of the day the above is all academic as I am still hunting down a supplier for ERW, there has to be a couple of them here in SA.
Edit to add: Does this appear to be the right stuff? http://www.robor.co.za/cold_rolled_tube.htm
Old 26th May 2009, 09:52 AM
ray3.2 ray3.2 is offline
Robor looks as good a place as any to get your steel from. Check out the DIN specs and BS specs on google.
Old 26th May 2009, 03:14 PM
Tatey's Avatar
Just rang up a local a local steel stockist recommended by flyerncle. Got quoted the following:
£10.85 per 6.1m - 25x25 16swg ERW
£6.45 per 6.1m - 19x19 16 swg ERW
£8.05 per 6.1m - 19mm diameter bar
So comes to a straight £100. Well pleased with that price.
Old 26th May 2009, 03:47 PM
A decent price is that
That is more than £50 cheaper than the last quote I had from my local stockist.
Don't be stingy when buying the sqare tube
7 lengths of 25x25 & 3 lengths of 19x19 ought to be about right. The jigs use away to some of the 25x25 & you wouldn't be human if you did not have the odd cock up when cutting the steel.
Best pay for delivery once
Old 26th May 2009, 05:20 PM
Would I lead you astray....?
Old 15th July 2009, 07:49 AM
fluxcored fluxcored is offline
Sorry to resurrect this thread - maybe I should have PM'ed Land Locked.
Land Locked .. did you manage to source some ERW. I had the same problem a few years back and just used RHS but Chris does present a powerful argument, I must say.
Cheers.
Laziness is a sign of sheer genius!
Old 15th July 2009, 11:11 AM
Flux, sadly not yet. Not a huge problem as I'm still trying to get the time to clear the workshop.(should have comfortable parking 4 three cars and all the benches, lucky to get one in at the moment)
The local guys keep asking what it's for and then insist that the hot rolled is more than adequate.(buggers) I may well end up getting a chassis pack off e-bay.
Old 15th July 2009, 12:29 PM
I'll make a few enquiries and let you know what I dig up but I've got a sinking feeling I'll also be forced to get an Ebay chassis pack.
I hear you. I absolutely hate the so called engineering shops and steel suppliers down here. Either they have'nt got a clue to what I'm talking about or am totally disinterested in providing assistance. I always end up shipping stuff in from Port Elizabeth and/or Cape Town.
