Old 1st September 2007, 04:04 AM
Lex Lex is offline
Default Engineering computations
Hi all,
Are engineering comps. available to support the design of :
1. Suspension arms.
2. Torsional rigidity and
3. The load carrying capacity of the frame?
Thanks Lex, at philrobin@aapt.net.au
Old 17th September 2007, 10:14 PM
Chris Gibbs
Hi Lex,
Unfortunately the calculations are not my property, and so I can't supply them.
The majority of the work was done using the ANSYS programme and you should be able to get what you need if you have the programme and the chassis dimensions or can get someone to do the calculations for you.
Sorry I can't be more help
Chris
