Old 10th July 2009, 05:59 PM
Beardy_John Beardy_John is offline
Default Pinto - Rocker Gasket leak
Quick one for you knoweldgeable chaps...
Cleaned the rocker cover yesterday and check the valve clearances. On further inspection I reckon all the cack and grease on the front of the block/belts/pulleys is coming from a leaking rocker cover gasket. Is the standard naff cork one actually any good, or can you use a liquid silicone one???
www.beardyjohn.com Build blog and associated ramblings (Updated - 17/07/09)
Old 10th July 2009, 06:56 PM
John,is the front oil seal ok. Try a new gasket with a little Blue Hylomar and not nipped excessively.
Its good enough for Rolls Royce so why not us mere mortals...
Old 11th July 2009, 10:18 PM
Do you put the Hylomar on one side of the gasket or on both??
Old 11th July 2009, 10:41 PM
I like to put a light smear on both faces of the gasket
The secret is not to overtighten the rocker cover retaining bolts & follow the correct tightening sequence.
Done my pinto engined Transit one last year, still as dry as a bone
Old 12th July 2009, 09:32 AM
On the nail as usual Ronnie .
