Old 19th July 2009, 12:06 PM
old_bill old_bill is offline
Unhappy front sb's
I started to fit the front suspension brackets and found that I have a gap between the chassis and the bracket. I have checked the frame dimensions and they seem OK. I had a word with Spikehaus as he had the same problem. There is apparently a thread on this but I can't find it.
Should I place a spacer between the chassis and bracket or should I manufacture new brackets with the dimension to the bracket hole altered to suit?
Thoughts and ideas appreciated
Bill
http://www.flickr.com/photos/old_bill/
Old 19th July 2009, 12:09 PM
just put a spacer behind the bracket, i too had the same problem.
Old 19th July 2009, 12:13 PM
My vote would be for a spacer too. I'm sure you will do something suitable strong, and I think that would be better and more rigid than a bracket with longer arms.
Old 19th July 2009, 12:47 PM
As with many others, I too had a gap that required a spacer ( 3mm to be exact )
Checked & double checked the bracket alignment jigs, spot on
As long as the brackets are in alignment with the book spec, all should be fine
Old 19th July 2009, 12:59 PM
fabbyglass
Don't shout at me but why not make the front chassis section that much wider to account for the gap.....
Old 19th July 2009, 01:02 PM
Probably because using spacers would be a lot easier/quicker than going back and redoing the front frame
Old 19th July 2009, 01:14 PM
fabbyglass
I would sooner redo the frame section
Old 19th July 2009, 02:03 PM
i have thought about this small issue & have looked at how to resolve it in a future build.
Old 19th July 2009, 02:58 PM
From the brief bit of head scratching that I done.
It would appear that it is the intersection point at the bottom of the front frame tube & the Two upright tubes that attach to it.
I can't name the parts because I do not have rhe book to hand.
If I were to build another chassis, I would ensure that the front frame was made to suit the brackets.
With the chassis fully welded, altering the front frame was not an option.
Old 20th July 2009, 12:27 PM
mark mark is offline
It seems as though the person who doesnt need packing behind these brackets is the odd one out on this one!
I did the same as have many others have just pack them out and weld em up!
