Old 2nd August 2009, 08:46 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
yes fair enough point and I was very impressed by the price.
If i was building chassis to sell id want a fair bit more, is that a starting up special price or are you planning to keep it that low.
Ray
Old 2nd August 2009, 09:16 PM
geeman's Avatar
geeman geeman is offline
Originally Posted by les g View Post
hi guys
just a heads up really
if you are building a chassis and INTEND to use FABBY,s side panels
you might consider a mod to the steering column support so you dont have to cut a lump out of your nice new shiny side panel
Fabby recomends stepping the outer leg of the support in by 25 mm for a nice smooth line
cheers les g
hi, never knew that, im yet to weld on the steering support, and as im getting fabbys side panels, i wondered if u had pics of what you mean as im not sure what you mean. Thanks
my build pics
Old 2nd August 2009, 09:28 PM
what i think Les is saying is when the time comes to fit the side panels the part of the steering wheel support frame that sits on the outside edge of the top chassis rail interferes with the side panel & so a little square has to be cut out of the side panel where it sits on the top rail at the point of the steering support frame,
hope that makes sense
Old 2nd August 2009, 09:29 PM
fabbyglass
It's no real drama but would be less worrying for folk if the rhs rails that support the column were inset a bit rather than sitting right on the edge of the chassis. Just means the grp sits on a little better and would help with doing ali sides too.
Old 2nd August 2009, 09:39 PM
geeman's Avatar
ok, roughly how many mm inset should it be or moved up, as im yet to fit the support,, it should be no problem moving it around a few mm. Thanks
my build pics
Old 2nd August 2009, 10:32 PM
les g les g is offline
Fabbys panels are snug
we are welding a bit of chamfered (both ends ) 25mm box to the inside edge of the top rail
and removing 25 mm from the horizontal piece of of the support so the R/H
leg is 25mm in from the top chassis rail
as Fabby says its no drama at all just makes it all that much nicer
and gives a bit more clearance in the scuttle area
its just easier to do it before than cut it off later or try and fettle the sidepanel around it
i,ll try and get TJ to post up some pics later in the week
cheers les g
Old 3rd August 2009, 08:38 AM
geeman's Avatar
ok, i think i understand it now, but if you could get pics that would be great. Thanks
my build pics
Old 3rd August 2009, 09:57 AM
RAYLEE29's Avatar
Dont you have to cut the scuttle too? I may move mine if it makes a neater job. I still have 1 cutting disc left at mo lol
Ray
Old 7th August 2009, 05:45 PM
fabbyglass
Yes you would need to notch the return edge on the scuttle.
How many places can the grp be bought from now as there is more and more folk doing the steel work side of it.
Old 7th August 2009, 06:48 PM
I tryed playing with that sticky smelly stuff awhile back when I was planning on making body kits for transits. Lets just say your in no danger of competion from me on that front.
