Old 4th August 2009, 11:06 PM
davidimurray's Avatar
Default Stripping - tips and tricks
Well - i've decided to go for a job as a stripper ....... only joking!!!!!!!!
Now your all disgusted by that thought - anyone got any tips or advice on stripping the sierra. Number one job I understand is to loosen the driveshaft nuts. Any more things to watch out for/do early on etc befoe i get it on the axle stands?
Old 4th August 2009, 11:08 PM
jasongray5's Avatar
Dont be gentle...
Old 4th August 2009, 11:14 PM
aaronbassett aaronbassett is offline
Talking
hack the car to bits more fun lol
my blog
Building is just another word for progress
Old 4th August 2009, 11:26 PM
jasongray5's Avatar
No just a good motto to live by! (for us farmer types)
Apart from the rear driveshaft nuts it is quite a straight forward job
I expect you probably know but for the benefit of any newbies that may read this at a later date. One of the rear driveshaft nuts, has a left hand thread, this can be identified by a small notch cut into the corners of the nut.
Go easy on the rear subframe mounting bolts, If they start to get tight, wind them back in & try to get some easing oil on the captive nut.
They are a pain in the ass when the captive nut breaks free
It may well pay to be methodical when removing the wiring. I like to use masking tape & a CD marker to lable each item that I disconnect. ( Memory like a sieve )
Good luck with the stripping Dave
Old 4th August 2009, 11:31 PM
Owww - that's a good tip on the left handed thread Ronnie - got the windy gun ready to go so that could have confused me for a while
Sorted the garage out today, chassis is leaning up against the wall and just use the space to do the oil on a mates focus (I now look like i've been working on an oil rig!) Saturday is the big day - Fire up the Sierra!
Old 4th August 2009, 11:42 PM
don,t set a match to it until you,ve got all the bits you need off it
have fun stripping it, & look forward to the time when you start putting it all back together again
Old 4th August 2009, 11:57 PM
Balidey Balidey is offline
Also worth putting an add on ebay for the parts you don't need. A few small bits of trim here and there can make it a break even.
Old 5th August 2009, 04:40 PM
if you get this months complete kit car there is a guide for stripping the sierra aimed at the haynes
