Old 11th August 2009, 05:10 PM
Homersdouble's Avatar
Homersdouble Homersdouble is offline
Default Front Hubs
Does anyone know if the sierra front hub oil seals are available on their own or do they only come as part of a kit ? I have stripped my hubs down and the bearings are OK but I don't want to put the seals back as they will almost certainly be damaged now.
Old 11th August 2009, 05:36 PM
It might be possible to get the seals from your Local Ford dealer.
Sometimes it is often possible to get this type of seal from a decent bearing dealer.
I have quite often managed to source obsolete seals this way
Here is a link that may be local to you
Bearing Services ltd ( BSL )
Old 11th August 2009, 06:43 PM
Jimmyd Jimmyd is offline
You can still order from your friendly Ford dealer at a cost. I can't remember how much but I remember thinking that's Bl**dly expensive.
J
Old 11th August 2009, 10:03 PM
7ishNZ 7ishNZ is offline
I got mine from a local bearing place... very cheap.
Old 14th March 2010, 08:16 AM
Jezzer99 Jezzer99 is offline
Has anyone managed to get hold of these seals? I'm in the same situation that the bearings all look good, the hubs are cleaned up and now all I need is the seal (and not a full bearing kit).
Looking at ebay the complete bearing kits seems to be around £15-20 and I'd rather avoid that if I can.
Ta.
Cheers,
Jeff
http://berkshire7.blogspot.com/
Old 14th March 2010, 10:00 AM
Try local motor factors,probably cheaper for full kit than e-bay.
Old 30th March 2010, 01:12 PM
Blimey... so went to the local motor factos... £31/side
Oil seals can't be bought seperately from them... surely there's an easier (cheaper) way?
Cheers,
Jeff
Old 30th March 2010, 01:23 PM
go to the local bearing company they will keep them.
Old 30th March 2010, 03:15 PM
That'll be about £15 trade then .... My local factors are a pain in the ass when it comes to dishing out the trade disscount
As Ash says .... I'll be most surprised if your local bearing company are unable to get the seals for you
Old 30th March 2010, 04:22 PM
Blimey... so went to the local motor factors... £31/side
Thieving Ratbags !
cant remember exactly how much they were per kit but not hugely expensive but I am in the trade and use them daily.
