Old 17th August 2009, 10:59 PM
Chris Gibbs's Avatar
Chris Gibbs Chris Gibbs is offline
Default Bulkhead connectors?
I'm looking for an 8 way bulkhead connector, you know the ones that have a plug on either side of a panel for easy disconection
Is there a special name for them 'cos I can't find one!
Chris
Old 18th August 2009, 07:21 AM
Land Locked's Avatar
Chris, if memory serves CAT use a lot of them. Try to find the nearest cat agents.
Also available from pheonix contact, their stuff is just horribly horribly expensive.
Old 18th August 2009, 10:29 AM
Balidey Balidey is offline
Its one of those things that different people call different things.
But I would possibly call it a 'cable pass through' or even as you said, a bulkhead connector
Old 18th August 2009, 10:31 AM
Hoybi's Avatar
Hoybi Hoybi is offline
Default try www.farnell.com
Hello Chris,
have a look at Farnell :
http://uk.farnell.com/bulgin/px0769-...50?Ntt=978-050
Or even better, ask for their catalogue (3500 pages !!)
You can order even 1 single item, sensibly priced, and (in Belgium) delivered next day withhout cost. Amazing. Have used them a lot for our automatic Lap timing system (www.chronostiming.be)
Eddy
www.alfaprojects.be
Old 18th August 2009, 12:13 PM
Thanks chaps - some good leads there, I didn't think they'd be so dificult to get!
Chris
Old 18th August 2009, 11:39 PM
les g les g is offline
Default multi pin connectors
Chris
check these guys out CEEP (website search ceep )
they do the fellows you are looking for lots of types small round and larger square/round
they are at
unit 7 haslemere ind est
Haslemere
surrey
gu27 1dw
some of our suppliers use there kit on plant and its good gear
cheers les g
Old 19th August 2009, 09:12 AM
RS components do this one
RS Components
16 pin but the price is quite reasonable for a three pice kit
