Old 8th September 2009, 11:05 AM
Rik178m Rik178m is offline
Default Just won some alloys, will they fit?
Cant get my head around the offset issue today. Just won some alloys on ebay pcd 108 offset 15. I know the offset needs to be 35-40ish. So my question is how do I get these alloys to fit or won't they?
Old 8th September 2009, 11:54 AM
slimtater slimtater is offline
"May" be a problem:
http://www.driverstechnologyassociat...eel-offset.htm
Old 8th September 2009, 12:14 PM
they will stick out about 20mm further than a wheel that is the correct ofset. if you have wide arches on the rear it shouldnt be a problem
Old 8th September 2009, 06:49 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Bumpsteer!!
Old 8th September 2009, 09:01 PM
Matthew Matthew is offline
Originally Posted by RAYLEE29 View Post
Bumpsteer!!
I don't think that's right. Bumpsteer is caused when the steering rack isn't correctly aligned (or the right length), and doesn't have anything to do with the wheel offset. IF you ever measure it then you don't usually have the wheels attached anyway.
I think it does have some other effects though - something to do with how well the steering self centres I think.
Matt
Old 8th September 2009, 10:13 PM
What exactly is bumpsteer?
If they dont work I'll just put them back on ebay.
Old 8th September 2009, 10:35 PM
Bumpsteer is the change of the effective length of tie rods due to the suspension travel. Nothing to do with wheel offset.
A wheel offset too low will shift the contact patch out of correct alignment with regard to the kingpin axis, thus increasing the scrub radius. The effect will be unsettled steering, exaggerated reaction to unevenness of the road, especially when braking.
Old 9th September 2009, 06:48 AM
If you want a more detailed explanation then this site http://www.longacreracing.com/articles/art.asp?ARTID=13 has a good explanation together with instructions on how to measure and correct it.
Matt
Old 9th September 2009, 12:06 PM
RAYLEE29's Avatar
Default Bumpsteer
Hi,
I believe there is more than one way of causing bumpsteer but i may be wrong, ive been modding cars for nearly 30 years and have experience of people fitting wheels with too much offset.
if you move the contact patch too far away from the middle of the point where the kingpin inclination hits the floor you will adversly effect the handling
when you go over a bump the car will try to steer into the bump if thats not bumpsteer what is it??
anyone remember the carlos fandango ad with the anglia with oversize wheels!!
Ray
Old 9th September 2009, 12:19 PM
Ray
That's a classic Ray.
Still makes me smile
Carlos Fandango
