Old 24th September 2009, 10:16 AM
chriseyj chriseyj is offline
Default Head light mounts.
Hi I have been making my headlight mounts because I thought it might be best to weld these in before I fit my wishbones and possibly get weld spatter on them below.
Trouble is I cant make out how long they are supposed to be in the book, unless I am missing something.
How far should the protrude either side? to headlamp mounting hole.
Cheers.
P.S got my oval tube from ikea bargain corner, 10p!
Old 24th September 2009, 12:24 PM
I don't want to be that guy.... But you can search for all this lot, this forum is a wealth of information. Whats worse is around 10 posts down is the recent discussion, complete with drawings, of the headlamp positions, centre points etc.
http://www.haynes.co.uk/forums/showthread.php?t=2744
Old 24th September 2009, 12:50 PM
Cheers for the link.
I did spend 10 mins searching and failed to find anything useful, tried several searches.
Thanks Chris
Old 4th October 2009, 02:43 PM
jasongray5's Avatar
Think the info for this must have been demolished my the site invasion.
Does anyone have info on where the headlight mounts should be positioned, and a rough idea of distance between the holes in them? I think they need to be wide enough, without touching wheels?
Thanks in advance guys!
Old 4th October 2009, 03:13 PM
Have a look at the 2 pics, they show all the lighting positions really well.
For the headlights as long as they are within 400mm from the outer edge and 500mm from road level of the car that's all you need. The rest are pretty straight forward....
Old 4th October 2009, 03:14 PM
Silly point, why not just remove the wishbones before welding in the headlamp brackets??
However, a simple search for "Lights" turned this up
http://www.haynes.co.uk/forums/showt...ghlight=lights
Hope that is what people are looking for
Sean
Old 4th October 2009, 03:59 PM
jasongray5's Avatar
Cheers Sean.
Dont know why I didnt think of just searching lights, Searched all sorts eg. Headlamp Headlight ect to no avail!
Exactly the info I was after tho!
Cheers spud, those pictures are now saved on my laptop!
