Old 9th October 2009, 05:42 PM
dogwood's Avatar
dogwood dogwood is offline
Yea, alright so I forgot to wax it !!!
I knew last night, when I see the wax sitting on the table.
I was just hoping it would be alright...
Second time round it's all OK.
Now comes the interesting bit, doing the modd...
Old 9th October 2009, 05:45 PM
May I ask, why are you widening it??
Is it a special extra wide chassis?
Sean
Sean
Old 9th October 2009, 05:56 PM
dogwood's Avatar
Sean
NO.....
Old 9th October 2009, 06:00 PM
fabbyglass
Dude,
Cut the scuttle in the middle then clamp it to your chassis, place yer splash mould on top and by whatever means you can clamp the two halves together then carefully flip it on its side and glass it up....jd as they say. Once cured pull splash mould off and have a go with some filler...
Old 9th October 2009, 06:03 PM
dogwood's Avatar
Sounds like a plan..
Cheers for all the advice.
I'll let you know how it went...
Sean you got a PM
Old 9th October 2009, 06:11 PM
fabbyglass
It's not rocket science although it can go bang if you get yer fag too close
Old 9th October 2009, 08:25 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
youll get there in the end and you prob wont make the same mistake again have fun,
my first bit didnt go to plan but the second try was much better
Ray
Old 9th October 2009, 08:36 PM
fabbyglass
It's fun turning runny stuff and some weird material into solid things that folk then turn into cars, nice to see the finished thing too.
Old 21st October 2009, 10:51 AM
VladD VladD is offline
OK, question from a newbie/thicky. What is a splash mould?
Old 21st October 2009, 12:58 PM
dogwood's Avatar
Probably not the right person to answer this, but
If you look at my pics, that is what I understand as a splash mould.
I put a couple of layers of glass over the scuttle to act as a mould when I widen it, so it still matches to the original...
David...
Mind you I could be wrong...
