Old 15th October 2009, 02:26 PM
Smile Bush tubes & Camber adjusters
Here you go chaps
As mentioned in another thread. Here is a full set of book spec bush tubes complete with a pair of camber adjusters + the 2 locking nuts.
When I bought my bush tubing I cut the full length up, hence the spare set that I never got round to selling on ebay.
The bush tubes were cut in the bandsaw then machined square & to length in the lathe.
I no longer require the camber adjusters & lock nuts as I have made quick adjusters for the rear of my car
The camber adjusters will require a bit of a wire brushing as they have been made a fair while & were originally only dusted with some satin black as a tempoary coating
The camber adjusters were made using high tensile threadded bar as opposed to general purpose zinc plated studding.
Heres a picy
22 bush tubes, 2 camber adjusters & 2 lock nuts
£25 the lot & including UK Mainland delivery
Hopefully this will do a fellow forum member a good turn
PM me if you are interested
Old 15th October 2009, 07:02 PM
Sounds like a bargain to me, will you be suppling a half round file to fettle them to the correct finished size? only joking
Old 15th October 2009, 07:20 PM
A round file should not be required
This was discussed in detail prior to the great forum melt down.
The concensus of opinion was to leave the weld seam unfettled as it provides usefull grip for the poly bush.
I have used the same material on my own wishbones in conjunction with 3GE's poly bushes.
Fit like a like a glove & work as they should ( Not too tight, not too loose )
The trouble with reaming this sort of material is that it is all too easy to overcook things & end up with loose fitting bushes
Old 15th October 2009, 07:31 PM
I did the same with mine Ronnie and have worked a treat...
Old 15th October 2009, 07:37 PM
look at the quality of the welding on the camber adjusters in the photo above then look at the photo of some camber adjusters on the ebay thread that cost more than Ronnie,s complete set , including delivery, thats a bargain with quality too
Old 15th October 2009, 07:47 PM
That's no ordinary weld, it's a M&S weld.........45 degree angle groud on the threadded bar for full root penetration OO-ER Missus
Old 15th October 2009, 08:27 PM
Which company is making the bushes, not just buying them in and moving them on but making the moulds and producing bushes 0.3mm under size?
Old 15th October 2009, 09:20 PM
I did the same, gave it a decent chamfer for a root, with plenty of weave. Nice straight cap after that.
Mine were grade 12.9 bolts with the heads cut off.
The offerings from GTS are shockingly bad - why leave the bolt head on? It looks mank
Go on, spoil us - who is flogging sloppy bushes??
Sean
Old 16th October 2009, 01:12 AM
jasongray5's Avatar
Would love to get my hands on a pair of those nuts Ronnie
Old 16th October 2009, 03:57 PM
Go the whole hog Jason and have the root penetration treatment too !
(you started it Ronnie !)
