Old 27th October 2009, 05:39 AM
7ishNZ 7ishNZ is offline
Why not block off the bottom outlet completely and put a "T" fitting in the other line.... they both come from the same pressure point in the cylinder......
Old 2nd November 2009, 01:50 PM
axle's Avatar
axle axle is offline
Hi
That looks very neat, but would the T-piece for the pressure switch need to go on the back line, I think it was suggested in the book?
Originally Posted by AshG View Post
i did it this way. dont run your brake pipes to the front tabs run them to go to the side pannels as the flexi pipe cannot pass through a gromet in the side pannel as i found out at a later date.
Regards Axle
Old 2nd November 2009, 04:57 PM
Tilly819 Tilly819 is offline
according to the iva man at gillingham the hose cannot touch the side pannel even if it has a gromet or rubber protecting it. it was suggested that the tab wasnt used and that the flexi lines were atached to the side pannels.
Oh bugger something elce for me to change
tilly
