#41
At least you got a decent deal on the chassis steel
I was recently quoted £120 for the box section Steel prices are usually quite volatile, luck of the draw where you live & local demand.
#42
£8 40x3mm 6 mtr flat strip FM steelstock
#43
They were the people i rang first who quoted me £25
. I guess the guy must have thought i meant bright. It did seem a little strange at the time that he said £25, as thats the same price they were charging for 1m x 0.5m of 3mm plate. At least i know for next time, if it doesn't seem right, it probably isn't,
1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting
#44
If you only want little bits Metal Supermarket on TVTE is ok and they will cut it for you but not that cheap.
And the carpark is huge !!!!!!!!! |
#45
Just given metal supermarket a ring. They are quoting £25.30 for 1000x500mm of 3mm thick mild steel plate. So they seem to be the same price as FM Steelstock are charging.
#46
All of my 3,5 &10mm plate was bought as off-cuts
60p per kilo I am very lucky that my local stockholder does a fair bit of fabrication. Normally plenty of bits n bobs kicking about if you can find anybody who can be assed to have a look !!?? ![]()
#47
Well i started making the chassis plates an hour ago, i've got 5 done so far. It really doesn't take very long and is quite satisfying. Only another 20 chassis plates (not including multiples) + jigs and other plates to cut!
#48
Armoto do a jig block,much easier to use.
#49
I'm not sure if they still do.
IIRC Jason has left, so no-one else bothered to do the chassis packs, I would imagine that extended to the wishbone jigs as well. Could be wrong though
Sean Last edited by londonsean69 : 4th November 2009 at 10:57 PM. Reason: Clarify information |
#50
Shame if thats the case Shaun, cos its an ace idea and works really well as I have one and its brilliant.
