Old 18th November 2009, 05:17 PM
Default Megajolt DIY
Well I thought I'd be smart and take advantage of the strength of the pound and order my Megajolt direct from the states in a kit form. I got the TPS kit, programming cable, mounting brackets and a hard rev limiter for £80 delivered to the UK.... In 3 working days!
Its bloody hard to put it together though. I've seen bigger fleas than some of the components. But after 3 hours I'd finished it. I've dug out an old windows xp laptop from the IT cupboard at work. So I should be able to test it out with the loom and engine in the near future.
Before
After
Old 18th November 2009, 05:35 PM
Well done mate
Looks horrible to do !
Old 18th November 2009, 10:24 PM
davidimurray's Avatar
Looks great - how hard was it to assemble? I'm currently toying with ordering the kit from the US to put together over the xmas break.
Old 18th November 2009, 10:30 PM
That looks like you've done a good job there.
I never did get on that well with soldering, although I did design and build my own Oxygen senser based on a quad op-amp circuit. Grabbed the wrong end of the soldering iron a couple of times though
I looked into the MegaSquirt DIY kit, but I don't have a steady enough hand to do it myself*
Any ECU I buy is going to be pre-assembled
*I have some residual nerve damage from a diving accident, at times, I get really, really shaky hands - no, it's not the drink
Sean
Old 18th November 2009, 10:41 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Take a look at the Trigger wheels website loads of good stuff on there Ray
Old 18th November 2009, 11:00 PM
les g les g is offline
contact Ray Ward
on locostbuilders he suppliies them built and tested with cable and disc of advance curves etc about £110 he charged me ...
i cant do fiddly soldering with my sausages
cheers les g
Old 18th November 2009, 11:15 PM
Looks a good job there, well done.
I bought mine pre assembled from trigger wheels. I'm the same as Les, too fiddly for my 6'7" hands......
Old 19th November 2009, 09:36 AM
Cool Cool
Looking good mate
I found it quite a relaxing way to spend an evenining
Right about one thing though, those surface mount components are tiny
Fine with the soldering once I got into the grove, never swore once.....Most unusual for me
Old 19th November 2009, 12:27 PM
Tatey's Avatar
Tatey Tatey is offline
I have to say im really looking forward to getting my hands on a megajolt system to build. I seem to really enjoy soldering components together and hopefully have something working by the end of it.
Old 19th November 2009, 01:04 PM
Here is mine after completion
[IMG][/IMG]
If you were assembling them on a regular basis, probably wouldn't take much more than a hour to do
Pitty I have changed direction on my engine install & probably won.t be needed.
