Old 25th November 2009, 11:52 AM
gingea1pom's Avatar
I’d be interested to please and how do you show a link to another web site with words instead of gobaldygook, i.e. the link in my signature is gobaldygook, I want it to say build pictures!
Build Pictures
Old 25th November 2009, 12:06 PM
OK, when you want to put a link in, you need to;
  • copy the link to your clipboard (right click on the text in the address bar and COPY)
  • In the reply, press the link button (looks like a world with a pair of handcuffs in front of it
  • Paste the link into the box that pops up (Right click - PASTE)
  • Hit OK
  • It then highlights some text in the reply, this is where you can change the actual text of the link, but not the location
For example; [url="this page.com"]Linky Link[/URL This would place a blue, underlined "Linky Link" on the page, and when click it would send you to "this page.com"
Obviously, the link above won't work, because it is not a real site, and I have removed some formatting to be able to show it. The highlighting should help work out which bit you need to change
So Ginge, in your signature, you need to amend the second set of gobblydegook.
Sean
Old 25th November 2009, 12:16 PM
gingea1pom's Avatar
Cheers Sean,
I will give it a go tonight as this work computer is sooooooo slooooooowww
Build Pictures
Old 25th November 2009, 12:25 PM
gingea1pom's Avatar
Sean,
I couldn't wait until I got home.
Look no Gobaldygook, a tidy signature.
You watch every post of mine from now on will have some sort of link in it!
Cheers again for taking the time to lay it out for me.
Ginge
Build Pictures
Old 25th November 2009, 02:40 PM
Chaps, you're both more than welcome
Sean
Old 25th November 2009, 03:03 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Thanks got most of it except the bit where you change the wording
Ray
Old 25th November 2009, 03:12 PM
gingea1pom's Avatar
Ray
Ray,
If you follow the intructions from Sean to the letter, once you hit return at item 5 of post 12 your cursor should be flashing in the middle of the URL.
Type away and low and behold it all works, well it did for me.
Good luck
Ginge
Build Pictures
Old 25th November 2009, 03:30 PM
Yeah, exactly as Ginge says.
Once the link has just been inserted on screen, the second bit of text in the link should be highlighted. If you just type over this, then you put in a title for your link
Sean
