Old 22nd December 2009, 10:58 AM
Originally Posted by adrianreeve View Post
The great thing is the process won't attack good metal, so bearing surfaces etc are unaffected
Yep, it does not etch rust and metal, it reduces rust to metal.
Old 22nd December 2009, 11:21 AM
Tatey's Avatar
Tatey Tatey is offline
Has anyone got a list of things you need for electrolysis? I'm trying to find a list and a guide but i can't seem to find one.
Also does it damage rubber seals etc? Finally what parts am i allowed to do? I know not to do disc brakes or the flywheel as they could suffer from hydrogenation (i think) and become brittle and shatter . My plan was to do the brake callipers, brake drums, front uprights and some other stuff if it works well.
Old 22nd December 2009, 12:06 PM
dan_g8 dan_g8 is offline
all you need is an 12 volt car battery charger, baking powder, a container to put your parts in and some scrap steel to surround your rusty part.
connect the + side of the charger to the metal surrounding your object and the - side to the object. pour the solution of water & baking powder into the container with your object and leave over night.
DO NOT USE STAINLESS STEEL THOUGH!!!!! it turns your water very toxic & harmfull. also dont get you + & - mixed up or your rusty part will be eaten away!
dan
Old 22nd December 2009, 12:08 PM
Tatey's Avatar
What else can i use other than a 12v car battery charger? As i don't own one at the moment.
Cheers for the guide tho.
Old 22nd December 2009, 12:11 PM
Here is an interesting artical in PDF format
Elecrolytic rust removal
This should help explain the basics & give a general idea of what is needed
Old 22nd December 2009, 12:19 PM
you can use anything that puts out arround 12 volts, 2amps & is DC.
Dab
Old 22nd December 2009, 04:32 PM
tigmatt tigmatt is offline
Here is another good link on electrolysis
http://www.stovebolt.com/techtips/ru..._derusting.htm
Old 22nd December 2009, 05:06 PM
Tatey's Avatar
Where does everyone buy their washing soda from? I had a look in Tesco earlier and i couldn't find any.
Cheers for the help so far .
Old 22nd December 2009, 06:39 PM
Soda crystals in the cleaning aisle of any supermarket.
Adrian
Old 22nd December 2009, 07:30 PM
frankie boy's Avatar
Adrian
What is a supermarket and where do i find one.
my Roadster
