Old 22nd December 2009, 07:36 PM
I'll let you know in exchange for a bodywork set when they're ready!
Adrian
Old 22nd December 2009, 08:40 PM
walter walter is offline
Default derusting
Hi all one thought on drusting parts ,if you know any one with a saftykleen degreaser,they do a liquid derusting soloutin which we tested for them at work,i thought it was going to be a gimmick, but it was brilliant and did what it said on the tin all you do is drop the part into the solution and leave it do its stuff .
Old 22nd December 2009, 11:46 PM
les g les g is offline
yep thats right we done the same at our work
its bloody expensive through them though
but the solution is talked about in the magazine article and available on the open market now walter
cheers les g
Old 22nd December 2009, 11:49 PM
Originally Posted by frankie boy View Post
What is a supermarket and where do i find one.
frankie boy
its like a pub or an offy you can buy beer and spirits there
but you cant drink em on the premises
i think they do stuff for barbecues as well
cheers les g
Old 30th December 2009, 12:27 PM
happyjo happyjo is offline
Cool electrolysis for beginners
Guys I found this website from the USA.
http://users.eastlink.ca/~pspencer/n...ctrolysis.html
Very good, explains why it works, what you need and what not to use.
Even suggests using a battery with the charger which helps the process and stops the parts/ charger causing problems for the charger and part being cleaned.
When I have my donor car then the soda crystals will be well used for this little project.
Happyjo
Old 30th December 2009, 04:23 PM
I made myself some washing soda (sodium carbonate) by heating baking soda (sodium bicarbonate) in a stainless steel pot. It's weird to see dry powder boil, giving off gases.
Baking powder is a mixture of sodium bicarbonate and citric acid, it is too acidic.
Old 30th December 2009, 05:12 PM
Tatey's Avatar
Tatey Tatey is offline
I managed to buy 1kg of soda crystals from Tesco today for the grand sum of 97p , i'll be derusting my components tomorrow
Old 5th January 2010, 07:31 PM
davielad davielad is offline
i believe you can use a higher voltage/amp to get fast/better results, therefore i am going to attempt to do it with my ark welder.
has anyone used the bath and welder setup?
Old 5th January 2010, 09:31 PM
Tatey's Avatar
Personally i wouldnt attempt to do it using an ARC welder. The power output is massive and if the current goes through you then it'll stop your heart, not worth it to save an hour at most....
Old 5th January 2010, 10:46 PM
aerosam's Avatar
aerosam aerosam is offline
Agreed - don't forget the hydrogen that is produced by the process, one spark and BANG!
I'm a big supporter of grit blasting rather than other methods for rust removal. CKC mag ran an article this month that said that it was unsuitable for components that are fragile or have extensive corrosion. Well, if the rust is that bad - would you really want to use that part anyway? Blasting gives instant results and leaves the part perfectly prepared for repainting. Although I should mention that it is critical that the part is given some surface protection within a couple of hours or rust will set in very quicly, as the process greatly increases the surface area of the part.
Machine mart sell a small cabinet for £118 but it realy is a worthwhile investment (provided you already have an air compressor). It can also be used with glass beads or walnut shell. If you have larger parts to clean, it may be worthwhile asking your local metal plating/galvanising/wheel restorer company for a quote to blast them for you.
Having said all that, electrolysis is a cheap method for doing a small number of small parts. And I guess we are all building a sports car, on a budget.
