Old 2nd January 2010, 06:07 PM
aerosam's Avatar
aerosam aerosam is offline
Default Can you shorten handbrake cables?
I just got some new handbrake cables for my (BMW) rear axle assembly and they are about twice as long as they need to be, obviously.
They are only sleeved halfway, as on the donor, the other half was inside the cabin. I can cut some length out of them here but how can I re-join them, as there is a threaded end that goes though the handbrake lever and is the adjustment point, which must be retained.
Thanks guys,
Sam.
Old 2nd January 2010, 06:26 PM
"wire rope" cable clamps available at most large hardware suppliers or of ebay.
Old 2nd January 2010, 07:43 PM
You could use brass or ali tubing and crush it. Pass both ends through the tube from each side,then turn them back on them selfs alone the outside of the tube and the pass back through the tube the as the first insertion. Crush with a vice total cost probaby nothing.
Old 2nd January 2010, 07:59 PM
i used these bad boys
Old 2nd January 2010, 08:23 PM
Yep.. "wire rope" cable clamps
Old 2nd January 2010, 09:16 PM
now i know the proper name for them lol
Old 2nd January 2010, 09:33 PM
dogwood's Avatar
dogwood dogwood is offline
I know them as "bulldog grips"
hey ho here we go....
David.
Old 2nd January 2010, 09:46 PM
Me too David
Even got a lin-bin in the workshop with a few in & that's what the Dyno-tape lable says
Must be our marine background mate
Old 2nd January 2010, 09:50 PM
dogwood's Avatar
Originally Posted by Bonzo View Post
Me too David
Probably....
David.
Old 2nd January 2010, 09:55 PM
Another option is to go to afishing tackle store and buy a wire trace crimp set the same thickness as your original cable .
