Old 21st January 2010, 09:46 AM
jasongray5's Avatar
So on your side pannels Andy, Did you follow the line of the front frame down, marking it onto the side pannel? then cut down that line?
Cheers Jas
Old 21st January 2010, 09:58 AM
Cheers Jas
In all honesty the drivers side panel was already cut down where it follows the vertical angle of the front frame, & some of the cut outs for the suspension brackets were also cut, tho i had to increase the cutouts to allow the up/down movement of the wishbones to allow the suspension movement.
I did cut the area around the steering rack gaitor & felt it was easier on the eye if that area was cut to allow the rack gaitor & front lower wishbone enough "clearance" in the panel in one cut....if that makes sense
If you look closely in the pics you can see some of the GRP that is part of the side panel that goes under the chassis & i think i might trim that down a bit too.
Old 21st January 2010, 10:09 AM
jasongray5's Avatar
ok mate, thanks alot! will hopefully get a go at that this afternoon or next week
Old 21st January 2010, 10:17 AM
look forward to seeing some pics of your car Jas,
nice one mate.
Old 22nd January 2010, 10:21 PM
GraemeWebb's Avatar
GraemeWebb GraemeWebb is offline
Originally Posted by spud69 View Post
Will be nice to see you both Graeme and Adrian, always nice to see builders faces and any excuse to get out in the car.............
Hi Andy,
Thanks so much for your hospitality yesterday. I thought I was pretty motivated in getting my car finished but after you taking me for a ride in your fabulous car my motivation is through the roof.
It felt so smooth and planted. Hope mine comes out nearly as good. I know what shock/spring combination to go for now. Would love to have the same engine setup as you but for the moment will have to stick with the Beemer 318. I will probably go for the bike carbs/megajolt like yours though.
Thanks again.
Old 23rd January 2010, 01:12 PM
Thanks Graeme,
I am pleased you enjoyed it and it was worth the trip over. The time to take people out is on the track on a dry day, the haynes comes into a class of its own then. Tested it against an MK on last track day and even though my engine was mis-behaving the MK couldn't touch it on the corners.
Again anybody is welcome to have a go on 9th April at teesside Autodrome.
Cheers....AndyH
