Old 30th January 2010, 08:50 PM
tkpm tkpm is offline
Default Rubber Engine Mounts
I will be hopefuly be doing a trial fit of my engine in a couple of weeks, the problem i have is, the rubber engine mounts where perished so i need to replace them.
The local ford garage does not keep them and there price to order them made me full over with shock
So my question is what can i use instead or can someone tell me where i can get them, there for a 2l pinto.
Thanks in advance
Terry
Old 30th January 2010, 08:58 PM
GraemeWebb's Avatar
GraemeWebb GraemeWebb is offline
Thanks in advance
Terry
I bought these : http://cgi.ebay.co.uk/Land-Rover-Ran...em3ef686c64 b
I am using a 4 cyl Bmw engine but these mount look neat and are cheap.
Old 30th January 2010, 09:08 PM
Tatey's Avatar
Tatey Tatey is offline
I will also be using these engine mounts, I also know that HandyAndy will be too., the engine mounts need to be motived to accommodate them though as they are not as big as the old ones.
Old 30th January 2010, 09:30 PM
gingea1pom's Avatar
I will be using the same as well on an 1800 CVH
Build Pictures
Old 30th January 2010, 09:35 PM
Thanks guys will go spend some cash on flea bay.
Terry
Old 31st January 2010, 12:22 PM
The land rover rubbers are the best to go for, they are cheap and give a nice firm support for the engine. The only problem is you shall have to remake the cvh engine brackets to suit.
A lot of people have had trouble with the sierra rubbers being perished so i think it would be wise for all builders to change their rubbers as part of the build.
AndyH
Old 1st February 2010, 12:48 PM
aerosam's Avatar
aerosam aerosam is offline
I bought mounts from car builder solutions, they do a nice range that aren't expensive so you may find a set to suit you without modifications.
