Old 31st January 2010, 11:53 AM
mr-p mr-p is offline
Default MT75 Pedal Box
Morning all,
Dont suppose anyone has a drawing of the MT75 pedal box, ive tried that rapid share link but dont get anywhere.
I want to check as there looks like little room to get me feet down there & the steering column supports are next to go on.
P
Old 31st January 2010, 01:01 PM
If this is any help,I have size 11 feet and Spud69's are larger (sorry AndyH) I have driven his car and no probs in the footwell area.
I am doing the plate and have made it 330x350 but it needs to be cut from the top and made to fit in two pieces as it not possible to get it in as there are to many different angles to take into consideration.
I am making it in 3mm plate and used 25x25 angle and 25 x3mm strip to sit the pedal brackets etc on .
Old 31st January 2010, 01:15 PM
If you look on this post:
http://www.haynes.co.uk/forums/showt...?t=2430&page=2
it has all the book amendments in it.
You will loose a small area from the pedal box but unless you have monster feet you will be okay.
AndyH
Old 31st January 2010, 01:40 PM
Cheers guys, off to the shed with the tape measure then...
Old 31st January 2010, 02:07 PM
Flynercle,
Are you sure about 350 dim as I cant see this working?? 250 x 330 seems better..
Spud,
Cheers for the link but I cant get rapidshare to download & the one I have downloaded previously I cant open for some reason.
P.
P
Old 31st January 2010, 11:40 PM
330 mm from from outside of upright to outside of the transmision tunnel upright u7 you may have placed it wrong as many do.
I will try to post a picture on Tues and you will see better what I mean
Old 1st February 2010, 12:10 AM
i have added the files to the first post on the page that spud put up
Ash
