Old 13th February 2010, 05:14 PM
Looking nice there Tatey
with the triangualted plates you mention, i can,t remember which way they are placed but if you wait until you weld in parts D12 then offer up the CP7 plates (triangle plates ) it,ll be easy to see their orientation
I,ve used scaffold tube for my cross brace in the roll bar, not that i,m advocating finding a building site tho
I also did the same as Flyerncle, where as my roll hoop was sunk into CP3 & CP4.
Your chassis is really taking shape, nice one mate
are you fitting an Ali rear tub?
Old 13th February 2010, 05:27 PM
Tatey's Avatar
Tatey Tatey is offline
Cheers Andy, by sunk into CP3 and CP4, im guessing you mean the roll bar mounting plates? And then bolting it onto CP3 and CP4? CP3 and CP4 are the large chassis plates with the 4 holes in them and the suspension mount welded onto the bottom.
Oh and yes I will be going for an ali tub, hence why i ordered 2 x CP11 + 2 x SS1 plates from you last week
Old 13th February 2010, 05:28 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, looking real nice there Tatey.
As for the cross brace, id bolt the plates to the chassis and weld the bar insitu then weld the crossbrace while its all bolted up then hopefully it wont be able to pull as it cools. you could also put a temporary brace between the suspension towers while you weld it up.
its normally as the weld cools thing start to pull.
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 13th February 2010, 05:33 PM
Tatey's Avatar
Sounds like a really good plan Ray.
I just need to see if my mate can come up trumps with some scaffy bar now.
Old 13th February 2010, 06:07 PM
yes, thats what i mean with regarding sinking the roll hoop,
doh.... oh yeah , ordered some plates, silly me
Old 13th February 2010, 08:12 PM
There is tons of it near the garage Tatey !!! And I have some too.
Old 13th February 2010, 09:09 PM
Tatey's Avatar
Flyerncle saves the day again!
Just an update on the roll bar situation. I finished fettling down the ends so that it was entirely level and the outer edge of the each side of the roll bar was 26.5mm from each edge, which to my eyes looks bang on in the middle of the plates.
I've also cut out a 50mm hole in the middle of one of the plates for the roll bar to sit though, as suggested by Flyerncle and HandyAndy, to give the joint some extra strength. I'll be doing the other side tomorrow and then welding it up, to quite a while to do with my pillar drill, hacksaw and rounded file, if only i had a 50mm slightly oval hole saw .
Cheers for the help everyone.
Old 13th February 2010, 10:06 PM
aarrrgh its purposly like that because when you weld the cross bar it pulls the roll bar in!!!
you are meant to weld the cross bar on first then weld it to the plates.
sorry i should have mentioned it in a more recent thread as it got lost in the melt down
Old 13th February 2010, 10:22 PM
Tatey's Avatar
I thought there might have been a reason for it being a bit too long . Ah well, make sure you let me know for next time eh
The upside of it is that i got to find out how good the new ceramic flap discs are
Old 13th February 2010, 10:46 PM
gingea1pom's Avatar
It makes perfect sense now. Well I have learn't something and every day is a school day.
Cheers Ginge
Build Pictures
