Old 15th February 2010, 05:52 PM
DennyB DennyB is offline
Default VW engine
Hi All, I am in the planning stage of building a locost and have been offered a tuned Golf GTi 8v engine with all bits (loom etc). What I would like to know has anyone else fitted one of these before and if so what g/box was used, any issues? Also does anyone have any dimensions / weight of this engine ?
Old 15th February 2010, 06:35 PM
Sadly, RWD boxes for VW cars are virtualy non existant.
You may be able to use the Porker 924 Torque Tube and transaxle set up.
Old 15th February 2010, 06:46 PM
http://www.golfgtiforum.co.uk/index.php?topic=121089.0
This would sugest that the Porsche belhousing is to the to the Audi 5Cylinder and not the VW4 Cylinder pattern.
I can't think of a readily available Transmission.
Old 16th February 2010, 08:02 AM
Land Locked's Avatar
Gilo engineering here in sarf efrika make custom adapter plates, bell housing and complete "conversion" kits. They are however NOT cheap.
If the old brain serves they do a VW to T50 bell housing kit.
I'll try n find a linky.
promised linky
Seems however that my old brain is failing or they've taken it off the list. The upside, they will do one off custom jobs too.
Regards (The mad Sarf Efriken)
Last edited by Land Locked : 16th February 2010 at 08:20 AM. Reason: add the linky
Old 16th February 2010, 12:41 PM
Hi All, looks like it is back to the ford option as with this being my first build I don't want to make it too complicated or costly.
Thanks for you advice.
Old 16th February 2010, 01:26 PM
Big Vern Big Vern is offline
Hi Denny,
It all depends on what you term as complicated. As I like a challenge and am terminally unable to do anything the easy way I'm grafting a Pinto onto an MX-5 gearbox!
You could try looking up websites that deal in adapters for formula race cars as the golf engine got used a lot in things like F3 a few years ago. But probably cheapest and simplist is to go with a ford engine.
HTH BV.
Old 16th February 2010, 03:21 PM
There's no advantage in using the VW engine, there are better units out there with RWD applications.
Don;t try to use the engine just because you have it.
Old 16th February 2010, 07:10 PM
les g les g is offline
Jon from 3ge
can put you in touch with a firm that supplies
adapter kits for a the later VAG engines
i dont know if the early golf motors have the same bell housing arrangement
but the guy would certainly fit you one up
after all he does mt75 to evo motors etc
he used to post on here but i have not seen him lately
cheers les g
Old 16th February 2010, 07:14 PM
VAG 20 v engine goes on a golf box and Geert from Alfa x does the adapter plate to fit a type 9.
Old 16th February 2010, 11:49 PM
there you go
somebody with a better memory than me was along shortly.....
cheers les g
