Old 19th February 2010, 09:45 AM
GraemeWebb's Avatar
GraemeWebb GraemeWebb is offline
as above post, more of these tanks on ebay, price £24.99 plus £9.99 postage,
item number 220555909809.
just in case any of the new members are looking for a cheap fuel tank, this tank fits the chassis to allow either a GRP rear tub or an Ali rear tub.
hope it helps someone.
I am about to buy one for my car. Has anyone had any problems? Is it worth it?
Old 19th February 2010, 12:41 PM
Enoch Enoch is offline
I just got mine, I think it will do the job nicely. It is not baffled, if you have an injected engine you will need an external pump, you will also need to weld in an extra pipe for the return. It comes with a level sender, you will need to mod the inlet pipe so that you can have a filler mounted on an external panel. As I understand it the filler in the boot area of the original Haynes design is an IVA failure - Don't know if anyone can clarify this point?
Good little tank for not much money, I reckon it's a lot less hassle than building one from scratch.
Old 19th February 2010, 12:54 PM
If the boot is not enclosed then I can't see it being a failure.
Old 19th February 2010, 12:58 PM
GraemeWebb's Avatar
Thanks for the helps guys. Just ordered mine. Get it on Monday.
Main task this weekend is make the front bottom wishbones done and fitted to my BMW uprights. Then mods to the uprights themselves.
Old 19th February 2010, 01:00 PM
Talking
I guess if the rear tub is not closed in & left open ( other than a top cover ) it would not constitue a luggage compartment & a filler point within will be OK for IVA
We'll know soon enough as Ash has his filler point fitted direct to the tank
EDIT
Beat me too it TT
Old 19th February 2010, 02:38 PM
I,m fitting an Aero style filler cap to the side of my rear tub & connecting it to the tank with the correct type fuel hose from CBS.
The tank sits above the height of the diff cage but is a good compromise for price etc.
the way i looked at it......... it would cost £20 for steel to make the tank, then the time , then the cost of a fuel sender etc......... but yet this tank cost me £29.99 delivered.......bargain if you ask me
