Old 20th February 2010, 10:26 AM
Default External Protrusion thingy..
There was a guy on ebay sellign a front nudgebar a couple of weeks back, Stating that it got round the issues of any front external projections.
I have read the section IN the IVA manual and I understand it fully ( HAHAHAHAHAHA NOT! )
Can somone tell me in laymans english what the rule is?
Taaa
Rob
Old 20th February 2010, 10:22 PM
Is silence a bad thing???
Old 21st February 2010, 01:47 AM
like adrian said really. the only real things that cause an issue are the track rod lock nuts, ball joint lock nuts and the bottom of the headlight mounts. luckily the sphere didnt fit through the other components to touch the shock absorber.
adrian what did you do to cover your harness brackets the rubber trim i glued round mine was deemed un acceptable.
Old 21st February 2010, 09:15 AM
Could you do a demonstration Ash ( video ) of what the tester did..
Are say for example the corners at the bottom of the headlamp round tube not an issue?
And from what you say, the sphere has to pass into Areas ( shock area ) if the can, so a grill is required to prevent issues with edges inside the nose??
Old 21st February 2010, 10:19 AM
no they didnt come but i was permitted to take a couple my own pictures although it was hard going as dave and i had to be quite involved throughout the test.
Old 21st February 2010, 10:34 AM
dogwood's Avatar
dogwood dogwood is offline
This is the type of thing our examiner required.
Said plastic U trim not acceptable
I've got 4 of them BTW Ash, I'll drop them off tomorrow
David.
Old 21st February 2010, 12:43 PM
cheers dave they will do the trick will have to give you some pennies for them.
all i need to do now is find a convex replacement mirror glass for my passenger side r1 mirror. failing that i will have to get some new mirrors.
Old 21st February 2010, 12:54 PM
Ash............
i,ve got 2 pairs of mirrors if you want to "borrow" them ?
1 of the pairs are from a Honda VFR 750 bike , others not sure of origin but are similar to the VFR ones.
let me know if you want to use them & i can post them off to you tomorrow.
Old 21st February 2010, 01:00 PM
the problem is i have r1 mirrors which are plenty big enough he just couldn't get them in a spot where he could see everything he wanted to. i think the only way out of it is either a convex mirror like the tester advised i should fit or a waking great big pair of mirrors to be sure of a pass.
im going to call yamaha monday morning hopefully they will keep convex mirrors for my unit or can tell me where to get one.
i don't really want to fit new mirrors if i can avoid it as it will mean drilling more holes in the scuttle and i may not be able to cover up the old ones which would ruin it.
