Old 25th February 2010, 05:57 PM
fabrun fabrun is offline
iges sent
just ask by pm, thanks
Old 25th February 2010, 06:04 PM
this is the donor car
i won't open another build thread now, because i'm going on with 3d
the build is for later
with the help of two friends
i 'm going to dismantle (or break) the car, modeling the parts, put everything in the chassis to see if it fit well
Old 25th February 2010, 10:33 PM
GraemeWebb's Avatar
GraemeWebb GraemeWebb is offline
Hi fabrun I used a E36 donor. If I can help (advice, sketches and photos etc.)just ask. You can see some of my mods on flcker link below.
Old 26th February 2010, 08:04 AM
thanks a lot graemewebb
i surely will ask you some question later
Old 5th March 2010, 10:37 AM
some news
i 'll add a balljoint and a mushroom soon
Old 5th March 2010, 10:38 AM
Old 5th March 2010, 11:05 AM
looking good that. what thickness plate are you going to use? i would think the top one needs to be substantially thicker with a tapered hole for the ball joint to seat into.
Old 5th March 2010, 11:31 AM
GraemeWebb's Avatar
Looks much like I have done/planning to do. Check position of top upright link relative to the Ford one to make sure suspention geomitry is right. Also, as Ash points out, thicken up the top plate of upright.
Old 5th March 2010, 11:57 AM
was also thinking it may be worth putting the top bolt through from the inside to out then welding the bolt to the plate and having the nut on the outside. that way you could then box it in and have a small access hole for the bottom bolt.
bonus is that it wouldn't add much weight and it would make it a lot stronger.
