Old 22nd February 2010, 09:45 AM
The joint is very close to the bulkhead on the sierra so I am a bit unsure why it's a problem.
This one has me a little confused myself
I understood that the Sierra's steering shaft is designed to collapse ..... One of the clamping plates on the triangular section is held in place by a shear pin & in the event of a frontal impact, this pin would shear & allow that clamp to slide up the triangular shaft !!??
Old 22nd February 2010, 10:25 AM
The later adjustable column has a sliding triangular shaft, the whole unit is a bit bulkier though.
Old 27th February 2010, 09:26 AM
Tallon???
Any news?
Old 27th February 2010, 12:01 PM
i can get single piece made to length steering shafts if anyone needs one.
will post some picts up of my modifications after i have had my lunch
Old 27th February 2010, 12:42 PM
God.... I hope it's only a ham sandwich and not a 3 course.... Get the pics up
Old 27th February 2010, 02:33 PM
Must be on the Coffee and Mints by now.......... Hope there's no brandy course!!
Old 27th February 2010, 03:13 PM
sorry got preoccupied with repacking my exhaust. bonus is that its now well under 99db. there was naff all wadding in the blooming thing.
ok back on subject...
this is how it was before. the inspector didnt like the fact that the bearing and joint were so close together. he felt that if i had an accident then the fire wall would have to collapse before the steering rack behind it collapsed
the solution he suggested was to put the bearing behind the firewall as this would demonstrate a degree of collapsibility
here is the picture.
as you can see the bearing is now held in place by a piece of 15mm plate made nicely to shape and welded to the chassis tube all the way round (was tricky i admit)
Old 27th February 2010, 03:59 PM
Is that an adjustable column Ash?
Old 28th February 2010, 01:09 PM
nope its a normal one.
