Old 7th March 2010, 02:09 PM
geeman's Avatar
geeman geeman is offline
Default Fuel system?????
Ok.. i think i may have actually set up the fuel lines incorrectly on my 1.8 cvh, hence why im not getting it to start, i say this as im not getting any fiel in the carb. can anyone explain to me how these go?
ok, in this pic one of these is fuel in?
WHere do these 3 go?
what are the 2 things circled??
my build pics
Old 7th March 2010, 02:46 PM
geeman's Avatar
ok, im almost certain ive got it all fitted correctly, as its the same as the haynes manual. But when i blow on the intake pipe, fuel is coming out of the return line. I think the line going to the carb is blocked as there is no fuel going into the carb.
my build pics
Old 7th March 2010, 02:53 PM
geeman's Avatar
From the fuel separator
1 from fuel pump
2 to carb
3 fuel return to tank
On the fuel pump I would say
1 goes to separator (1)
2 From petrol tank (Via Filter I would suggest)
On the carb
Hose clip is from fuel separator (2)
Bottom hole circles would have probably been the hose to the brake servo so needs to be blocked off.
Adrian
oks, thats how its set up, however, no fuel it gfetting to the carb, it come straight back from the return when i crank it.
I also am getting little puff from the exhaust when cranking
my build pics
Old 7th March 2010, 03:35 PM
Poor some petrol ( just 20ml or so into the carb venturie )
Crank it and as you do give it veryvery slight throttle.
It should fire and run briefly, and may stimulate fule to enter the carb.
Old 7th March 2010, 03:36 PM
p.s. watch for backfires spitting out the carb... Not common but can happen...
Old 7th March 2010, 03:37 PM
Fuel should flow out the return at quite a pace once the float chamber is full.
Old 7th March 2010, 03:41 PM
If it does not start with a splish down the carb then pul the plugs, are they new?
Are they wet with fuel? if so Dry them in the oven at 100c for half an hour and if they are not new give them a light rub with sand paper to clean up the electrodes.
Also confirm you have a spark by placing one of the plugs in the lead and connecting it's threaded portion to the block with a good jump lead. if theres no spark when cranking you still have an ignition issue.
Old 6th April 2010, 05:23 PM
geeman's Avatar
ummm.. Ive just realised i haven't fitted a return fuel line. Now i was always under the impression carbs don't need return lines? Do i need a return line on the 1.8 cvh, if not what do i do to the return fuel line...
my build pics
Old 6th April 2010, 05:33 PM
gus's Avatar
gus gus is offline
Did even fit the vapour seperator in my fuel system. Engine runs fine. IMHO I would throw the seperator in the nearest bin, and connect the pump straight to the carb.
Gus
Old 6th April 2010, 05:36 PM
geeman's Avatar
Gus
ok, problem sorted then. Thanks
my build pics
