Old 8th March 2010, 08:12 AM
Enoch Enoch is offline
Default Headlamp mounts.
I have just about finished my chassis now, I only have the headlamp mounts to do and a bit of tidying up. My question is - how have people made the headlamp mounts IVA friendly? It seems to me that they would have to be made of at least 5mm thick tube to get an acceptable radius on the bottom edge. I understand that sticking a bit of trim on there is not acceptable any more so how have other builders got around this? Your thoughts would be appreciated....
Enoch
Old 8th March 2010, 08:55 AM
I used a bit of 3mm walled tube for mine .... May be completely barking up the wrong tree !!?? ... But If you are only puting a radius on the outside edge, you'll only need material thicker than 2.5mm ??
You could also choose a size of tube that you can get a plastic end cap for Bop that in there .... that should take care of any radius issues
That said .... I havn't been through the IVA ...... Yet
Old 8th March 2010, 10:31 AM
Thanks Ronnie, as I see it if they van make the test sphere contact any part with a radius of less than 2.5mm it's a fail point. I don't know if the sphere can touch the inner edge. Your idea of a cap has triggered an idea though..
Thanks for your response.
Old 8th March 2010, 10:38 AM
Ash Is probably well placed to answer, since his got the fine tooth combe
Old 8th March 2010, 10:51 AM
you are fine with the u-trim on those as u-trim is what would be used on a normal car. just make sure its the stuff that has the metal liner up the middle of it rather than the floppy rubber stuff.
Old 8th March 2010, 11:22 AM
So is this on the bottom of the round tube that the headlamp bolts into?
Old 8th March 2010, 12:04 PM
TT, yes, that's what I am on about.
Ash, thanks for that. I was under the impression that the U trim was generally considered to be a temporary fix and therefore unacceptable. Thanks for the info - that makes life a lot easier.
Enoch
Old 8th March 2010, 12:14 PM
U trim is ok used in the correct application like trimming body panels etc. what is not acceptable is stuck on bits of rubber u channel on places it wouldn't be normally intended for.
Old 8th March 2010, 12:53 PM
Big Vern Big Vern is offline
In other words, Ash, if its what you'd expect to see on a production car then its Ok. If you wouldn't expect to see it on a production car then its not!
BV
Old 8th March 2010, 01:58 PM
Can't say I have seen u trim on many production cars mind
