Old 6th March 2010, 11:27 AM
ginger ginger is offline
Default Thickness of floor ?
Hi am going to weld a steel floor but not sure of thickess can any one advise
Old 6th March 2010, 01:23 PM
Personally im going to use 2mm and weld it in.
Old 6th March 2010, 06:04 PM
fabbyglass
My floor is thick, it doesn't have a clue what day it is let alone what 2 and 2 are...makes me wonder sometimes it really does...
Old 8th March 2010, 07:41 PM
james3004's Avatar
i'd say 2mm ali, or 1.6mm steel, but it upto you
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 8th March 2010, 08:57 PM
Jimmyd Jimmyd is offline
I've a 2mm steel floor, mainly because I had the sheet just sitting there!!
J
Old 15th March 2010, 07:07 PM
aerosam's Avatar
aerosam aerosam is offline
mine is 2mm ali chequerplate - because it's what i had lying around.
I'm sure you are already aware of this, but isn't a 2mm steel floor going to be REALLY heavy?
Old 21st May 2010, 11:06 PM
Josh's Avatar
Josh Josh is offline
Question ali grade?
Rather than start a new thread I thought i'd bump this one up.
My question - I'll be using 2mm thick Ali for my floor but the supplier gave me a choice of grades - what do i want?!!! 1050, 5083 - these numbers mean nothing to me....
Cheers!
Josh
Old 22nd May 2010, 10:02 AM
gingea1pom's Avatar
Josh,
I am no expert but I have found thiswhich might be worth a read,
Someone with more experience will be along in a minute.
Cheers Ginge
Build Pictures
Old 22nd May 2010, 10:07 AM
5083 is much better. Try and get a decent hardened one as well, T25 or something.
Old 24th May 2010, 02:30 PM
Josh's Avatar
Blackburns Metals down in Edenbridge say they would recomend and can supply me with a 2m*1m*2mm thick ali sheet of grade 5251-H22. Can anyone in the know say if this is what I want?! Cheers
