Old 9th March 2010, 05:19 PM
Tilly819 Tilly819 is offline
Default Iva Results
ok folks here goes
unsuprisingly i failed but there isnt much to fix and my tester was VERY nice and told me evrything i needed to do extremely helpfull, seems to be rarther inpressed with the entire car (even if i do say so my self hehehe)
Test started at 8:45 ish was done by 10:45
failed on
1) Emissions: basicly im sure you will remember a few days ago we thought it was running lean....well actualy it was running rich..... VERY rich so blew my emmissions test out compleatly
Fix: power comander and dyno run
2) braket that holds rear break pipe T peice lightly to vibrate
Fix: make a new one out of steel as oposed to the ally one curently fitted
3) interiour fittings: internal rad on dials not 2.5mm
Fix: glue on O-Rings round the dials
4: Steering wheel pad not hard enough has to be shore 50 and i need to mount it in a more profeshonal way ie not insulating tape
Fix pad with tougher foam and secure with velcro
5: exteriour projections track rod lock nuts and top ball joint lock nut
Fix: wireing gland gaitors on track rods and ball joint gaitor over the ball joint lock nut
6: wheel arches to short do not cover full dia of wheel
Fix: extend front of arch
7: front indicators angles of visability
fix: mount on nose cone
so all in all a good test, very quick, very plesant once i new id failed i realy began to enjoy it
since i found out the engine was running rich rarther than lean i drove it home as well insted of putting it in the trailor...
chears tilly
Old 9th March 2010, 05:29 PM
Well that's not so bad Tilly
Other than the emissions ........... The rest should be a doddle to fix
I guess you'll soon have that list sorted & back for a re-test in the very near future
Well done mate
Old 9th March 2010, 05:31 PM
a BIG well done Tilly,
Thats a "good" fail, won,t take long to sort it out.
I imagine you enjoyed the drive home eh??
Old 9th March 2010, 05:32 PM
Tatey's Avatar
Tatey Tatey is offline
Congrads Tilly, thats a nice small fail list there.
When you say the front arches are too short, where did you get them from? Just so I know to avoid them.
yeh hope so, iv just welded in a boss for a lambda for the Rolling road, spoke to a chap eirlier said it should be a doddle..
as for the rest a few evenings should sort it
tilly
Old 9th March 2010, 05:33 PM
Enoch Enoch is offline
Well done Tilly and thanks for posting the results so we know for our own tests. Does not sound too bad at all as long as the emissions are sorted without too much grief.
Well done that man
Old 9th March 2010, 05:35 PM
think the i got the front arches second hand carnt remember were from, dont have a recipt...
drive home was great ....... saw 2 rozzers one on a island wouldnt have seen that is didnt have plates and the other drive straight past me with nothing elce on the road, to be fair i had a IVA TEST plaque stuck on the back
tilly
Old 9th March 2010, 05:38 PM
Oh think iv found out why its running so rich as well.... when i was on the phone to the chap at the rolling road i told him id removed the stock air box and fitted the ITG socks and he sais they are rubbish and really restrictive, once took a set of a street car and emidetly gained 10HP lol
tilly
Old 9th March 2010, 05:52 PM
mark mark is offline
Thats not bad at all well done!
Hope my list is as easy to fix as that
Old 9th March 2010, 05:55 PM
Just out of interest .... How is your roll bar fixed .... In particular the backstays .... One bolt, Two bolt's or welded
Just thought it would be usefull to know & gauge if there are variations between test centres
