Old 17th March 2010, 07:58 PM
Eternal Eternal is offline
Default Transmission tunnel help
Hello all.
Have been doing research and im trying to work out what to do with the tunnel when i make the chassis. Seeing as there are quite a few sierras out there with MT75 gearbox;s should i just make the chassis to MT75 size reglardless of what donor i will eventualy get?
My question is... my endgame plan is to install a 13b engine and gearbox from a fc3s into the chassis i dont suppose anyone knows what tunnel size would be best to make this fit?
Old 17th March 2010, 08:10 PM
Pics from a versoin with the engine and gearbox. duno if you can tell from just pics.... pics from Rons locost build
Old 17th March 2010, 08:24 PM
Enoch Enoch is offline
that looks a damn site smaller than a type 9. Is it in a standard width chassis? If so there is tons of room to spare with the standard tunnel dimensions. If you saw the size of an MT75 bellhousing you would see what I mean - it's huge.
Enoch
Old 17th March 2010, 08:25 PM
Hi Eternal,
Its not easy to gauge from the photos but i reckon as that engine sits so far forward in the chassis I think you might be ok with a type 9 tranny tunnel, tho if you can get a width measurement around the bellhousing in line with the starter motor ( thats what i think it is ) I,d be able to give a more confirmed answer.
Also as i presume your car will be right hand drive then there is no reason why you couldn,t narrow the passenger footwell width a little, its plenty big enough as no pedals in there etc.
That way you wouldn,t lose "foot " space in the drivers footwell as you would if you fitted the MT75 tranny tunnel.
hth
The other thing is it looks like a very short engine so could be made to sit further forward so the gearbox would be even narrower at the point it passes the forward trans tunnel tubes.
Old 17th March 2010, 08:26 PM
That damn Andy beat me to it
Bloody bloke!!
I really cant tell from the site listed most of it is just pics. i guess you can work it out from looking at the chassis steering support position but im not that used to the chassis to be able to tell. I do know that the rotarys generaly sit a little forward so maby thats it? I got to get this worked out as its my main plan so any help research would be great! lol
Edit: lol loads of replys in the space of 1 min!
Old 17th March 2010, 08:28 PM
Bloody bloke!!
heheheheheh
soz Enoch
Old 17th March 2010, 08:31 PM
I just tried to post a photo but it's too big so it gets rejected. PM me your email addy and I will send a photo of the MT75 sat in a modded trans tunnel. I think it will give you the answer you need.
Enoch
Old 17th March 2010, 08:36 PM
http://i856.photobucket.com/albums/a...g?t=1259299971
http://i856.photobucket.com/albums/a...g?t=1259300645
looks more pushed back. i guess it depends on where i want the gear stick...
