Old 25th March 2010, 09:37 PM
Default Exhaust Manifold
What's the general consensus for getting a decent exhaust header for a Haynes? I'm not desperate for one, but the one I've modified off the RS2000 isn't ideal. I'm at the point of cutting a hole in the bodywork for it and would be awfully upset if I make the hole and find a better manifold with an alternative path through the bodywork!
Old 25th March 2010, 10:45 PM
Tilly819 Tilly819 is offline
I made one, its definetly an expencive way of doing it but the finished result is spectacular even if i do say so myself and you can make it go were ever you want it to.
tilly
Old 26th March 2010, 07:10 AM
dogwood's Avatar
dogwood dogwood is offline
Tell me about it...
I made my header, It looks pooo
But couldn't afford a better one at the moment.
Will defo get it changed when I can
Think it wil be a new bonnet for me (Alloy (TF) )
David.
Old 26th March 2010, 09:18 AM
Hello Deezee,
Having an RS2000 manifold i guess you have the CVH engine, if you have a look at the pics i used a manifold off a Focus ST170 with pipes extended to bring manifold out of bonnet and the outlet modifying slightly to fit down side of car onto back box, gives you a good high flow exhaust that you can then put onto a Zetec. You can get these for about £100 off e-bay. The RS2000 is design to use with a turbo so doesn't matter too much for free air flow.
Lot better than having a full exhaust made up for £600.
AndyH
Old 26th March 2010, 12:30 PM
mark mark is offline
Spud i think you have had a senior moment and got the rs2000 which is a 2litre twincam mixed up with an rs turbo which is a 1.6turbo cvh
The st170 is a good choice to make a free flowing manifold though
Old 26th March 2010, 12:58 PM
Yes you're right there mark, but "1 out of 2 ain't bad" or was that 2 out of 3.....
Old 26th March 2010, 03:13 PM
Yeah the RS2000 manifold is a 4-2-1 and I was thinking about what you did Spud, but wanted to keep the manifold on the inside for aesthetics, with just the 2 pipe section coming out.
I can see this being a real thorn in my side. I'm keeping an eye out for other decent manifolds for RWD use and trying to modify them to fit.
Old 27th March 2010, 09:21 PM
jonnyd281 jonnyd281 is offline
I've seen a 4 into 1 kit to make your own exhaust manifold on EBay, you get everything you need to make your own, just weld together.
Old 28th March 2010, 12:06 AM
One on ebay seems ok for the 99quid +10 postage.
this is the link to it.
http://cgi.ebay.com.au/LOCOST-VINDIC...item4a9e25e351
