Old 28th March 2010, 09:08 PM
Luke2842's Avatar
Luke2842 Luke2842 is offline
Default Size of a finished Roadster??
Hi All,
Just trying to sort out a bit of much needed garage space and just wondered if anyone knew the rough length and width of a finished Roadster.
Old 28th March 2010, 09:19 PM
slimtater slimtater is offline
Sure someone will measure theirs but from memory, mine was 10'10" x 5'8".
Old 28th March 2010, 09:34 PM
I could measure mine in the morning(not at home) if someone doesn,t give you the info sooner.
Old 28th March 2010, 09:39 PM
I wonder if I can squeeez both the roadster and MK1 golf in the garage at the same time.. Think the golf is about 12ft long.. May even get my sapphire and roadster in at the same time. Must measure the max internal length but it's about 27ft...
Old 29th March 2010, 03:28 PM
As promised........
total width at extreme outer edge of the rear wings (widest point)= 172cm
total length at very tip of front nose to edge of the rear tub at the lowest edge = 331cm
These measurements were taken from a Roadster with the GRP rear tub.
hope this helps.
Old 29th March 2010, 07:07 PM
Luke2842's Avatar
Thanks for that, at least it should about fit in more tidying needed though!
Old 29th March 2010, 08:10 PM
As promised........
hope this helps.
So like I said, 10'10" x 5'8"!!
Old 29th March 2010, 08:57 PM
spot on Slim
