Old 5th April 2010, 10:01 PM
Ahhh yeah.. I looked on CBS but could not see em..
Not cheap @ Harry Potter Sport.. ( Quideach )
But then P Clips aint Cheap either..
Build Cost Ģ4181.65 - Last - Wheel Cylinders
Old 5th April 2010, 10:12 PM
Cool Brilliant stuff Janne
Your chassis is looking superb.
I think I may very well have found my new chassis colour
One can certainly see that there is some high quality work going on there
Old 6th April 2010, 07:29 AM
Janne E Janne E is offline
Talking
Thanks for the nice words
About the clips I think I got them from Merlin
Handy I think there will be a little surprise even for you ...
Old 6th April 2010, 09:26 AM
now , I like surprises
what what what is it???
Old 21st April 2010, 03:07 PM
Smile
Time for a little uppgrade!!
The chassi is almost done and itīs on wheels.
So now I started with the engine and gearbox, first I took it outside for big washup.
Then i took it all apart and cleaned it all up.
I will replace the bearings shells the piston rings, oil and waterpump the camshaft bearings. I got a new camshaft a Kent cam FR32. The head will be skimmed for 1.5mm and I will modify it a little bit. The flywhell is about 1.5kg lighter. At the top it will be a pair of dellorto 40mm.
It will not be a raceengine but I hope for about 130-140hp
Regards Janne
Old 21st April 2010, 03:26 PM
Very nice Janne....
Garage looks far too clean and tidy, some nice gear there to.
Well Done and keep it up....AndyH
Old 21st April 2010, 07:51 PM
Roadster is looking very nice Janne
& as for your workshop wow so clean & tidy, & like Spud says...some nice equipment too.......
let me loose in there for half an hour.........I,ll soon make a mess
looking forward to seeing the engine running video & some bodywork fitted.
Old 4th August 2010, 06:35 PM
Hi Guys!
Itīs been a long time since I uppdated, but here it comes
My health has been bad for a few months so everything I do takes much moore time
So what has happened...
The engine is done and painted, the brakes is done and I have mounted some of the bodywork and a lot of other small things....
The nosecone has hinges in the bottom so I can flip it if I want.
[IMG][/IMG]
Old 4th August 2010, 06:53 PM
Some moore pictures....
Old 4th August 2010, 07:01 PM
WOW Janne....That is stunning
The car really is looking very nice indeed,
I,ve just noticed the steel plate across the top part of the front upper wishbone brackets, nice touch
I must ask......how do you keep your workshop so tidy ?
won,t be long before you,re on the road?
