Old 7th April 2010, 10:41 PM
jasongray5's Avatar
Ive just had a dig through my recepts and ebay to see if i could find where i got it from to point you in the right direction, no luck tho.
I keep thinking that spending is nearly finished, but then remeber stuff like, wheels and tyres, megasquirt, wideband, prop, sigh...
Anywho, sorry i cant be of more help mate
Old 9th April 2010, 09:08 PM
Smile All is good
Just to tidy this thread up.
My new release bearing arrived this afternoon.
Here's a picture of the two bearings side by side, may be of use to others at a later date.
The standard Sierra bearing is on the left ( CCT132 ) & the Capri bearing is on the right ( CCT133 ) . Both are QH part numbers.
It can be seen that the CCT133 bearing is about 10mm thicker & will allow enough throw on the Zetec clutch.
Not the cheapest of bearings at £26.93 but needs must & all that
They managed to get the part in direct from QH stock & was a next day service.
This was also the factor that I used to obtain my Maxi & transit joints, I seem to remember that the prices for them was quite good
Anyway folks, that's me sorted & all is good with the world once more
Old 9th April 2010, 10:54 PM
martin62 martin62 is offline
Hi Ronnie can you tell me whot I would need to match up a 2.0 zetec to a type 9 ie.sump/starter and clutch Thanks Aidan
Old 10th April 2010, 08:33 AM
Hi Aidan
I believe there are a few options open
As the 2 Litre flywheel is so heavy, most folk opt for the much lighter 1.8 Zetec one.
Possibly if using the original 2 Litre flywheel you will most likely be able to use the standard CCT132 Sierra release bearing.
If using the standard flywheel you'll need to find a clutch friction plate that is the same diameter as the Zetec one & has a 1" 23 spline centre.
The standard sump can be adapted to suit but again, most folk opt for the 1.8 Zetec one or a lowered 1.8 CVH one.
You'll need a 1.8 CVH starter motor as I believe the zetec one fits the wrong side of the engine for the type 9 gearbox .
A spiggot bearing will be needed for the flywheel, this will support the type 9 gearbox input shaft.
Very easy to fit as the Zetec crankshaft is already drilled to accept it. The bearing can be got directly from Ford or found on Ebay.
Finally you may want to use the 1.8 CVH sandwich plate between engine & gearbox ..... That said, I don't think they are very easy to get hold of .... So at a guess, I would say that folk either alter the Zetec one or just don't bother to use one !!??
Here's my set up
1.8 Zetec engine, from a 1992 Mk5 Escort
Lowered 1.8 Zetec sump
Mk1 1.6 / 1.8 Mondeo clutch cover & friction plate
QH CCT133 Clutch release bearing
1.8 CVH starter & sandwich plate
Flywheel spiggot bearing
Ford Capri Mk1 clutch cable
Type 9 Gearbox
I hope this is of some help to you .
Old 10th April 2010, 09:04 AM
Coozer's Avatar
Coozer Coozer is offline
Glad your sorted Ronnie, basically same setup as mine there..
Problem with the 2L flywheel can be the thickness. Some fit the type 9 bellhousing, some don't!
On my ST engine the flywheel was bigger than the bellhousing aperture and simply wouldn't bolt up to the engine!
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 10th April 2010, 11:47 AM
Smile Thank's Coozer
Cheer's for the heads up on the clutch to use Steve
That tip saved me a fair few bob as was looking to buy separate components
Blagged a nice new Mondeo clutch kit for a very decent price
Old 10th April 2010, 08:52 PM
Hi Ronnie thanks kor your help hope to pick up the black top on monday and see what I need Thanks Aidan
Old 10th April 2010, 09:56 PM
As for the spigot bearing, its number in the SKF catalogue is HK1516. They're a bit cheaper at the bearing factors. Haven't gotten mine yet, but I'll give it a try.
Old 10th April 2010, 10:07 PM
Cheers for that part number Albert
I am really pleased that I have managed to get the engine & box all fitted together.
All covered up & put to one side for the time being.
I have finaly managed to get the chassis back on its stands .... At last I can start the final fitting of the mountain of parts I have to hand
Old 13th April 2010, 06:40 PM
Yay, for once I'm getting something cheaper than you guys! The bearing factor had some inventory of a factory that went under. The bearing cost me only 77 pence! I'm tempted to buy a bunch of them and sell on ebay for 10 quid apiece, free shipping!
I tried it, it's indeed the right size.
