Old 9th April 2010, 09:09 PM
geeman's Avatar
geeman geeman is offline
Originally Posted by Josh View Post
Some more questions... I'm going to use 2mm ali sheet for my floor - how would you suggest I mount my seats? Would it be enough to bolt them straight to the ali plate or would I be better off welding some steel support tubes in between the lower rails and transmision tunnel rails? I'll be using seat runners nicked off my 5door metro as it'll almost cirtainly fail its next MOT in a few months beyond economic repair
I think most people including myself will weld 2 strips of some steel(im using 40x3mm), and put the runners on those. I think some people have used some 25mm box instead of strip as well.
my build pics
Old 9th April 2010, 09:22 PM
gingea1pom's Avatar
Josh
Josh,
You really don’t want to fix your seats straight to the aluminium they would probably rip out on hard cornering.
Weld some steal strip or box section as Geeman has said, should keep the IVA man happy.
Cheers Ginge
Build Pictures
Old 9th April 2010, 09:50 PM
My car has an ali floor, so i,ve welded in some 25mm box tube between the bottom rails/ transmission tunnel,
apart from the strength of the seat anchorage it also raises the seats up to a nice level, i can now see the top of the headlights & front wings , when i,m in spuds car I can only just see over the top of the aero screen
Old 9th April 2010, 10:37 PM
SeriesLandy's Avatar
What you can see all depends on your height mate . Although your not that short.
Old 10th April 2010, 08:12 PM
Josh's Avatar
Josh Josh is offline
Today was the last days building for 4 weeks, back off to Uni tomorrow. Got started on removing the rust from my front uprights via electrolysis and played around with the seat heights with the nose cone in place.
I think I'll weld in some angle strips across the bottom rails with some captive nuts welded to the underside for me to bolt my runners too - I too think that the slighty higher seat position will help with my view out the car!!
Me in my chassis (day dreaming !)
Josh
Old 10th April 2010, 08:28 PM
looking great there Josh ,
I,m sure we can all admit to sitting in the chassis & dreaming / longing for the day we get to drive it
May I ask which gearbox you plan to install?
Have fun at uni ( which uni by the way? my lad is at Lancashire Uni.)
Old 10th April 2010, 08:38 PM
Josh's Avatar
I was going to use the type9 and built the car acordingly, then changed my mind did a straight swap for an MT75 with a guy after a type9 (lucky!) and made the trans tunnel mods accordingly.
I'm at Bath in my second year studying Mechanical Engineering, although will be taking a year out in industry starting June '10 working for Williams F1 - can't wait!!
Josh
Old 10th April 2010, 08:46 PM
wow, a fantastic Industry placement & your Roadster build will I,m sure be a great talking point of your time with Williams.
Your chassis is looking great, you,ll soon have it on wheels , then sitting in it saying Brum Brum
My lad is studying to be a teacher......( teaching English & History in Japan )
Old 10th April 2010, 09:01 PM
I can 200% say I would not want to be a teacher. I have worked in a school for 12 years and realy can't work out how they cope with some of the crap they have to put up with... But then again, I am just plain poor at teaching people stuff.. Give me a computer network issue and I am quite happy though
Old 10th April 2010, 09:03 PM
Josh
Remember, your earnings do not have to have a ££££ value. 30 minuets with your chassis in the care of one of the chassis dynamics boys could be worth a shed load..
Just don't push ya luck
Should be a briliant placement
