Old 14th April 2010, 12:02 AM
DaveyB DaveyB is offline
Default welding settings
Hi,
has anyone used a clarke 151 TE to weld the chassis with? i purchased one recently but haven't used it yet. Can anyone give me an idea of the appropriate settings for welding the chassis rails.And does it need to go into a30 amp cooker style socket or will the normal plug sockets be ok.
Thanks, any help would be greatly appreciated.
Dave.
Old 14th April 2010, 12:17 AM
Tatey's Avatar
Tatey Tatey is offline
I have the Clarke 151EN which is pretty much the same welder. A standard 13amp socket works perfectly fine. And the power setting will depend on what size mig wire you are using along with the shielding gas.
I use 0.8mm wire with co2 shielding gas and have it set to either the 3rd highest or the 2nd highest setting with a wire speed of 6.
Have a play around with the welder before welding the chassis, make sure yourself a shelving unit like I did, it helps you improve your welding, as well as getting used to your welders 'temperament'.
Old 14th April 2010, 09:01 AM
I use a similar welder Dave and each one will have its own idiosynchrosies (long word for this time of morning). I use second highest out of 4 with a speed of 6 but then we use 2mm box section for 16 gauge as ginge says 3rd setting should be fine. Practice on a few sections first to get you penetration.
Mine is a great little welder but i'm sick of it overheating on constant use so about to upgrade to a Portamig 185, made in the UK and gets great reviews.
Enjoy.....AndyH
Old 14th April 2010, 09:09 AM
dogwood's Avatar
dogwood dogwood is offline
As Spud says, they do overheat somewhat..
I welded with it set on "1 and high", found that higher than "2 and low"
David.
Old 14th April 2010, 10:00 AM
portamigs are nice welders spud. are you getting it from weldquip? when you use it you will wonder why you mucked about with a clarke for so long.
My Pictures
Old 14th April 2010, 10:14 AM
Or just get hold of a damaged Lincoln Electric V160-TP that someone thought was broken and it was just a busted switch! Saving of over £800. Super Bargain!
Old 14th April 2010, 10:23 AM
i have got a migtronic, can weld box section all day without it cutting out
My Pictures
Old 14th April 2010, 10:37 AM
Portamig is from Weldequip Ash, but they are made to order - 5 to 7 days. But i want it NOW, got a lot of welding to do and am pissed with mine overheating now, has been a good welder though....
Sounds like you got a bargain there Dogwood....
Old 14th April 2010, 11:10 AM
Smile
Thanks for all the advice, I'll have to try some settings as suggested and see what results i get.
Thanks again.
Dave.
Old 15th April 2010, 03:58 AM
ACE HIGH ACE HIGH is offline
I built a steel 32 ft yacht 36 years ago with a 150 amp arc welder,it overheated badly so I set up a 12 V car battery alongside it with a heater fan,it was a standard Smiths type probably from a Rover 90,it worked a treat.
Or simply buy a 240 v electric fan and with a bit of playing around with cardboard or ply make up an intake for it,even drill a hole or holes in the side.
The old smiths heater fans put out a huge volume of air,I assume modern fans are just as good,flog the one out of your donor!
Maybe a bit of roof drainage pipe throught a hole in the side will do it.David
