Old 15th April 2010, 09:55 AM
Thats a good plan ACE, i tried similar myself but it didn't work for me.
Deciding now whether to go for a new Portamig or a Lorch Pro Synergic.
AndyH
Old 15th April 2010, 10:48 AM
Coozer's Avatar
Coozer Coozer is offline
Ooo, I have a Portamig 185 from and its great... doesn't like a 13amp plug though, a 16amp commando is the required item, simple to wire into a spur.
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
Old 15th April 2010, 11:02 AM
ACE HIGH ACE HIGH is offline
Maybe a vacuum cleaner,either blowing or sucking,perhaps remove bag and final filter, will cool your welder.Only a small hole will be needed or use the fan head.
I painted an Austin Kimberley with a vacuum cleaner 30 years ago using oil based house paint and a very good job it did too! Cheap and quite pro.
I also stuffed my wifes vacuum cleaner 30 years ago when I accidentally "sucked instead of blowed" the red hot charcoal ashes from a producer gas unit I made for an old Massey Harris Tractor.Yes it worked well.David
Old 15th April 2010, 11:03 AM
Coozer's Avatar
Now then, that's talent!
Old 15th April 2010, 11:05 AM
Perhaps an electric garden vacuum/blower,a huge volume of air?????David
Hi Steve,
Your 60x40x3mm box section is coming in tomorrow, 6m length for £20.
If you come down in your everyday car you could take the mig gas bottle with you.
AndyH
Old 15th April 2010, 11:11 AM
Coozer's Avatar
Cheers Andy, yep, that's the plan. See you Saturday!
Cheers!
