Old 30th March 2010, 08:57 PM
Smile Gearbox done today
I managed to give the gearbox a good cean & lick of paint today.
What is it with pressure washers !!?? .... No matter where you aim or stand, it just comes straight back at you .... Usualy straight in the face
Came in from that job like a drowned rat .... If I had a bit of common sense, I should don some waterproofs .... Aint got time for that though, I am on a roll
Diff next & thats the last of the heavy duty cleaning
Old 30th March 2010, 09:01 PM
Davey's Avatar
Davey Davey is offline
Lookin' good Ronnie, you can come up here and do mine next if ya like .
D.
Old 30th March 2010, 11:00 PM
D.
I'll send my big brother over
He lives in Shropshire .... Tis about time he got his hands dirty doing some propper mans work
Old 30th March 2010, 11:09 PM
I know exactly what you mean on the preasure washer.
I found a wire brush in a drill quite effective on the gearbox.
Old 31st March 2010, 10:52 PM
onedayTM onedayTM is offline
hi ronnie great job, I'm doing a zetec as well and was interested to hear you say you might be having a go at your sump. does it need to be cut, cause there is not much difference between the sump and the bit that bolts to the gearbox. If it needs cutting would be interested in how you will go about it.
tony.
Old 31st March 2010, 11:04 PM
Tilly819 Tilly819 is offline
looking fantastic, keep it up !
tilly
Old 1st April 2010, 12:27 PM
tony.
I'll keep you posted on my progress Tony
I noticed that when I offer the CVH sandwich plate to the Escorts Zetec engine ..... There is a fair bit of spare flange that is surplus to requrements & could be cut off
My thinking is that with such a deep flange, it gives the impression that the base of the sump does not require altering .... I have a sneaky feeling once I have removed the surplus flange, i'll see a differnt picture.
Will try to get some pictures up shortly
Did manage to clean up the diff yesterday but have not painted it as yet.
Edit
Tony
I thought a new thread in the engine & transmission section would be usefull .
Old 18th April 2010, 05:50 PM
Your engine looks fantastic, Ronnie. What treatment did you use for ally parts? Is that silver paint on the head and sump? If so, did you use an etch primer? In general, what do I have to do in order to make my Zetec look as good as yours?
Old 19th April 2010, 06:04 PM
Could you post me the spare deep flange please Ronnie
Box looks pretty.
Old 20th April 2010, 09:32 AM
Sorry Albert, I missed this one .... I blame old age
The engine block & gearbox castings were degreased, then pressure washed.
Any loose material was removed with wire wheels and anything else that could be got into the tight areas .
Once de-greased, all of the Blackwork was given a couple of coats of High temp Engine Lacquer.
The alloy work had the same prep .... A little bit more work involved in removing the surface " White dust " Probably due to the fact of my geographical location and it's Salty enviroment .
All of the alloy was painted with a couple of coats of Silver High temp aluminium paint .... Needs no etch priming & has proven to be quite durable over the many years I have used it.
That said, on the head, it will probably tarnish a little as time passes.
The rocker cover was given a darn good clean & again it took some time to remove the White dust.
It was then treated to a few coats of Very High temp manifold paint .... This dries to a matt finish & it's primary use is for exhaust manifolds / downpipes.
Just chose that for looks realy.
The Black is, Tetrosyl Engine Laquer (150 deg c)
The silver is, Blackfriars Aluminium Paint (150 deg c) .... I have used this stuff for years & it has served me well .... A tiny brushfull goes a long, long way
The Red was a Halfords own brand product, VHT Exhaust paint .... Small spray can & the rocker cover got the lot
