Old 20th March 2010, 05:54 PM
Default Strange Bones with bold claim...
Aparently these suit ALL seven kits!!
http://cgi.ebay.co.uk/LOCOST-7-ROSE-...em4a9f956b fc
Old 21st March 2010, 07:26 AM
Davey's Avatar
Davey Davey is offline
Interesting shape. I can't see them fitting my "seven type" though .
D.
Old 21st March 2010, 08:55 AM
eSteve's Avatar
eSteve eSteve is offline
AdrainH,
it's pretty close;
18 swg = 1.21920 mm
see:
http://www.bulkwire.com/wiregauge.asp
eSteve
Regards,
eSteve
Old 21st March 2010, 09:00 AM
eSteve's Avatar
I see rose joints are used as opposed to a bush.
Rose joints seem to be used alot on American kit cars. Wouldn't they give a very different feel to a bushed joint, having practically no inherent complience as you'd get with a bush?
Regards,
eSteve
Old 21st March 2010, 09:25 AM
Spherical rod ends ( to give them a generic name ) are usesd all the time for track applications but are a bit unforgiving on rough roads. they are also usualy open to the elements ( a fail on IVA i think ) and the dust and grime will wear them out ,
Old 23rd April 2010, 09:29 PM
there used on trains and are pritty resilent to wear and grime tho there would be no give in the joint at all
rubber boots can be aquired to keep the dirt out
if anyone where useing them i would recomend nylon lined ones as thay are not to harsh but its so thin your practily running metal to metal
the only place i had thort of useing them was to repace the top balljoint/trackrod end for top of the front hub and maybe the rear ajuster to
Old 24th April 2010, 07:18 AM
Had spherical rod ends on the rear end of my Formula 27 as standard and that was a lovely car to drive ,not harsh at all.
