Old 9th May 2010, 11:42 PM
tkpm tkpm is offline
Default Complete Engine Build Advise Needed
As i have some spare cash from selling my bike, i'm going strip my 2l pinto engine completely down as i have no history on the engine.
What i need to know what should i be replacing or doing to the engine
i.e.
inlet and exhaust valves and seals
head skim
piston rings
Cam?
all advise greatfully received
Terry
Old 9th May 2010, 11:46 PM
Tatey's Avatar
Tatey Tatey is offline
What are your overall plans for the engine? Are you going to swap it out for a zetec engine later on, or will you just be sticking with the pinto? If its the former, then you may want to hold off spending money on the engine, as it could end up being a bottomless money pit.
I got my hands on a 1.8 CVH which i stripped down and was planning on rebuilding, it wasn't a runner and required at least £150 to get it going with a complete rebuild. I managed to buy a 94 1.8 zetec engine which is a known runner for £40.
Old 9th May 2010, 11:50 PM
At the moment i'm going to stick with the pinto, the engine did run before i removed from the donor.
Terry
Old 10th May 2010, 12:48 AM
Your not going to know till you rip it apart.
But for a full rebuild
Bottom End
Gasket Set
Breaters
Crank check and grind if needed
Main Bearings to suit
Big End Bearings to suit
Oil pump Strip, clean, check and replace if needed
Bore Hone or rebore
Pistons to suit
Rings to suit
New water pump
Top End
GAsket Set
Head skim
Cam Bearings
Valve Seats for U/L
Valves to suit
New guides
New springs
Rockers checket and replaced
Cam Replaced
Oil Spray Bar
Restud Manifold faces
Cambelt
That's about it.
Old 10th May 2010, 09:06 PM
Big Vern Big Vern is offline
If the Pinto was running OK when removed from donor then just replace oil and filter, (you've got to drain the sump to mod it anyway) and fit new plugs and leads. set valve clearances and LEAVE IT ALONE!
Go any further and it'll cost big bucks and it ain't worth it!
Last time I rebuilt one to fully recon. spec like TT's list, (in 2006) it cost nearly a grand.
For a tenth of that you can get a good silver top Zetec which is more powerful straight away.
BV.
And since you need £1400 for the SRi you won't have big bucks to spend on the Pinto
Old 10th May 2010, 09:46 PM
Bolt the engine and box together put the starter in and do a compression check,it will give you some idea of the state of the internal's.
Old 10th May 2010, 09:50 PM
My Usual is..
See if it runs on the garage floor. If yes then fit it , if no buy another.
Once in if it seems ok then just use it and see how it goes.
Old 10th May 2010, 10:08 PM
Quick update,
Head is being skimmed
Crank is being polished
The bores are being honed (if thats the right word)
All for £80
then i will sort out piston ring and bearings when i get the big bits back
Terry
Old 11th May 2010, 04:01 PM
Headshot Headshot is offline
My Usual is..
Now THATS a moto I aim to build mine to
Old 11th May 2010, 05:32 PM
Coozer's Avatar
Coozer Coozer is offline
£80 wasted when you could have bunged a zetec in for an instant upgrade in power, economy & reliability.
Mate of mine has just sold a zetec with shortened sump and flywheel, clutch etc for £40, I've just picked up a 1999 1.8 zetec for NOWT!
LG,
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
